loose wire
Old May 31, 2011 | 02:40 PM
lavery48's Avatar
lavery48
Default loose wire
I replaced my harmonic balancer on my '98. I have it all back together except for one wire that I don't know where it goes. It's on the drivers side in front of the eng.It looks like comes from the fan wireing harness and it has a blue connector on it. I can not find where it plugs in. Thanks in advance.
Old May 31, 2011 | 02:47 PM
lucky131969's Avatar
lucky131969
Originally Posted by lavery48
I replaced my harmonic balancer on my '98. I have it all back togeather except for one wire that I don't know where it goes. It's on the drivers side in front of the eng.It looks like comes from the fan wireing harness and it has a blue conector on it. I can not find where it plugs in. Thanks in advance.
Wire color? Post a pic.........
Old May 31, 2011 | 04:11 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Old May 31, 2011 | 05:56 PM
TOPCATHR's Avatar
TOPCATHR
im not saying that it is the fan wire, but i did install a adjustable temp switch and the low speed fan wire is light blue................
Old May 31, 2011 | 07:05 PM
lucky131969
Are you the previous owner of the OP's car?
Old May 31, 2011 | 09:29 PM
TOPCATHR's Avatar
TOPCATHR
no why?
Old Jun 1, 2011 | 06:42 AM
lavery48's Avatar
lavery48
I tried to post a pic. but never figured out how to do it. Sorry. The wire's look grey and split off the wireing harness that goes to the Engine fans.
Old Jun 1, 2011 | 07:51 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Open an account with photobucket as one possibility, upload and save the picture. Select the picture then touch or Ctrl C the "Direct Link". Come back here, select the little icon with a mountain and sun in it(Square) which will open a place to put that link in there. Ctrl V into that small window and say ok. Save the reply and your picture will appear.
Old Jun 1, 2011 | 08:43 AM
lucky131969
Ok. First you said "wire".......now it's "wires". They can't both be grey, so if I had to guess, based on so little information , I'd say the wires were white and grey, .....and they connect to the magnasteer on the rack.
Old Jun 1, 2011 | 09:53 AM
lavery48's Avatar
lavery48
well lucky, I had a drop light underthere but it was still hard to see the wires, they are in a single housing and they were light colored, maybe white & grey. I had the steering rack out of the car so that might be where it pligs into. Thanks so much for your help man.
Old Jun 2, 2011 | 08:59 AM
lavery48's Avatar
lavery48
OK, I found where to plug the wire. It was at the steering rack just like you said Lucky. Thnaks for all the help man.
Old Jun 2, 2011 | 09:10 PM
lucky131969
To loose wire
