Pulled plugs to check
Old Apr 22, 2002 | 12:35 PM
Scruffy's Avatar
Scruffy
Default Pulled plugs to check
for oil consumption. I am using about 1 qt. every 2000-2500 miles. I pulled two plugs and they looked "good". The insulator was very light tan and the tip and electrodes were clean. There was a little sooty looking build up on the flat bottom edge of the threads. Sorry no pics.
Does this sound normal for a car with 6,000 miles or am I being too paraniod about the oil issue? My concern is eventual carbon buid up in the combustion chambers from any burning oil.
Old Apr 22, 2002 | 12:49 PM
vettenuts's Avatar
vettenuts
Default Re: Pulled plugs to check (Scruffy)
Doesn't sound any different then my 02.
Old Apr 22, 2002 | 03:58 PM
carpe dm's Avatar
carpe dm
It takes the rings some time to "seat"; you may have to drive awhile yet to see your consumption stabilize at a lower level. After 6K , I had NO measureable consumption ! Still not a drop @ 36K. :) Of course, I have an auto trans and that makes a difference.
Old Apr 22, 2002 | 11:21 PM
Skeeter1's Avatar
Skeeter1
how do you drive ? easy, hard ?
Old Apr 23, 2002 | 01:00 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Pulled plugs to check (Skeeter1)
You should feel fortunate that you only burn 1 qt per 2k. That is with in GM spec (if you believe that )... I go through a qt every 800 mile, but then again I run mine hard everyday...
Old Apr 23, 2002 | 09:46 AM
wcj's Avatar
wcj
Default Re: Pulled plugs to check (ICULUKN-C5)
I may be out of touch with the engines of today, but about 13 years ago I was a mech for 30 years and I built alot of engines. almost all of the stock engines that were built would get about 2500-3000 miles to a quart of oil ( usually needed a quart just before scheduled oil change) and anything hypo that was beat on got 1000-1500 miles to a quart. this was considered good. I am not familure with the LS-1 motor yet and I know that it was a ground up redesign, but I assume that even though it is an aluminum block it has steel sleeves. naturally no one with any brand new car wants to experiance any oil consumption but if a car is beat on you have to burn some. we also used to use regular fossil oil, cars that were raced we would put 20-50w into and cars that were driven normally got 10-40w. today I see my vette uses synthetic oil with a weight of 5-30. we wouldn't use synthetic oil, not because of oil burning but because of low oil pressure readiings. my two cents worth :nopity
Old Apr 23, 2002 | 07:18 PM
Scruffy's Avatar
Scruffy
Hard some of the time and never babied. I do run it thru 1st and 2nd to redline several times per week but I do not consider that abusive at all. I will cruise along at +3k rpm for short distances if I know I'm going to have to pick up speed quickly. The LS 1 doesn't have much grunt down low IMO.
Old Apr 23, 2002 | 10:22 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Scruffy- as you have probably heard, GM says that on the '01 cars oil consumption goes up dramatically if the engine is running above 3200 rpm under light load. That sounds like exactly your condition. With your low mileage and driving style, I'd say that 2k per quart is pretty good. Not that it should be that way.....
Old Apr 23, 2002 | 11:08 PM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: Pulled plugs to check (Gearhead Jim)
Why shouldn't it be that way? No oil consumption early in life may mean high oil consumption late in life. An engine that does not use some oil isn't getting lubricated properly.
Bill
Old Apr 23, 2002 | 11:27 PM
c5pilot2001's Avatar
c5pilot2001
Yeah, I heard that, too, from my service tech :bs My 2001 coupe is at the dealer now having other things repaired (again) and am considering re-ringing the motor. Thankfully,I still have my old car (a '91 Acura Integra -- lovingly referred to as Grandpa) that I have beaten like a red-headed step-child since day one. 140K miles later, I can drive it over 4000 rpm in traffic to and from work and it never burns a drop of oil. When this car had 125,000 miles I drove from Washington, DC to Jacksonville, FL in 7 1/2 hours (do the math) on oil 7500 miles old to see my mother in the hospital. That same weekend I changed the oil, 4 qts out, 4 qts in!
SHAME ON GM for blaming the driver's right foot for what is clearly an engineering oversight. Zora should be turning in his grave right about now.
To Pulled plugs to check
