So a bit of background ... I have a 2002 LS6 that has BB shorties gutted cat stock xpipe with stock TI exhaust. The motor has LS6 ported heads from Texas speed and a cam that is very near a G5X2 profile. Last year the car put down 426.
In late feb / march she dropped cyl 7 due to what I think was a week injector and common cyl 7 problem. Lost compression and I decided to rebuild back to stock. Motor was pulled and we honed the cylinders installed new rings on stock pistons as well as polished crank with new bearings.
Motor went back in and I decided to put a used Xpipe back on that had the cats intact then after a few baseline pulls the motor made a best of 416.5 at 11.75 Air/Fuel .... We then decided to put the Xpipe with cats gutted on and car belted out a 429.83 with 12.55 air/fuel. Both runs were 91.16F and 19% RH ...
So yes we took a bit of fuel away but do think the cats made the biggest difference ... I was always under the impression that cat removal was pointless but in my experience it did make a difference.
(note i may put them back on just cuz its not quite as loud and smells so much better)
Sorry, no amount of tuning will get rid of the stench-close your garage door for 10 minutes sometime with a car with cats vs. one without. Bet you'll change your mind then (assuming your still alive from the no-cat experience).
having lived most of my life in AL, where you can smokescreen the town to the point the weather channel erroneously predicts a storm in your area, its kind of common to run w/o cats here. its widely known that if you're doing intake/exhaust mods, the cat becomes noticeably restrictive.
the added smell may or may not be worth it to you, depending on what you're doing, and if you live in a smog-test area you're boned.
dougbfresh: why dont you sit in a garage for 10 minutes with your engine running and let us know how that goes for you on any car? cat or not cat, these things dont spit out unicorns and pixie dust..
With all due respect sir, anyone who sits in their garage with the door down for ten minutes trying to tell the difference in a car with cats and without is a complete MORON!!!
Instead of getting into an internet battle with you I will simply say, please reread what I posted as it clearly says, "will HELP" with the smell, not totally cure the problem.
I guess running to cats in Hickville is OK-we have to get inspected regularly here.
My last Vette, a 69' had no cats-you would not want to be in a closed space for more than 2 minutes with that car running. If you think your doing much by removing the cats, your NOT. I live in an area where every 2 years we get tested-it's not worth the hassle (or the extra 2hp gain) to "F" with the cats. Cat's are not perfect, but it's a PROVEN fact, they do help cut down on the junk shot out the tailpipes that we ALL breath.
Guess some of us can ignore the laws we don't like just cause' we want to.
I definetly beg to differ. My garage has a 72 C3 454 with open sidepipes and a 68 mustang and neither one ever stink up the garage. I can let either car idle in the garage and never smell anything other than hot car (and burning oil in the case of the mustang) so if a carb can be tuned to not smell then a fuel injected car can too. This of course not to mention my catless C5 has no smell either. Just a simple mail order tune from ECS took care of that. On the stock tune it stunk like raw fuel. After the tune nothing.
I may be a little biased though, I really like the smell of gasoline, oil, burning rubber and that distinct iron and salt smell of all the blood and sweat I left inside the engine bay burning off.
I have a 98 with H/C, LT headers, X-pipe and no cats. It has a B&B
exhaust and can idle all day in the garage. The tune and air fuel ratio
is the answer!!!! It has 10K on the clock with no problems and my
county is smog exempt in CA.
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Where was the wideband? If it was after the cats (ie. in the tailpipe), that's the reason why you got different A/F readings. Cats really mess with widebands. They should always be placed before the cat when tuning to get accurate readings.
