Valve train reassembly
Old Jun 2, 2011 | 02:01 PM
dragon84's Avatar
dragon84
Default Valve train reassembly
Did you guys put loctite on your rocker arm bolts when you reassembled? I have two different sets directions. One says to do it, the other doesn't mention it. Also there was no sign of loctite when I removed the bolts and rocker arms.
Tom
Old Jun 2, 2011 | 02:18 PM
bumble-z's Avatar
bumble-z
The GM manual doesn't call for it on reassembly.
When I switched out my springs last fall, I applied motor oil to the bolt head flanges & threads as per manual instructions.
Good luck.
Old Jun 2, 2011 | 02:32 PM
dragon84's Avatar
dragon84
Good luck.
Ok thanks man!
Yea, I need to get the 3 vol manuals.
To Valve train reassembly
