front wheel sensors 2000 vette
got a problem with the abs/active handling/traction control lights on.
the left front sensor.
erased codes came back
checked all connectors, clean.
check for continuity at itemediate cable and good there.
checked for ac volt and ohms at sensor and according to what i've read on this forum, i'm within specs.
have check connector at abs, clean and seated.
was going to switch hub/sensor with right side. a whole lot of work if i'm missing something else.
i've checked the ac volt and ohms with right side and both sides are consistent.
any help welcome!
thanx
dave
thanx for all replies
i found the problem.
after initially checking the connectors on the intermediate harness (L)
i had continuity. put all back together i didn't have continuity at the
main harness end of the cable. pulled it apart and checked again, i had
continuity. smells fishy! pull the sensor end connector apart and found a broken contact. pushing the probe of a multimeter into the connector had given me continuity. the probe forced the broken metal
contact to touch the broken pieces together, thus, giving an ohm reading.
repaired connector, put back together, cleared codes....voila no codes.
