brake lights and turn signals
Old Jun 4, 2011 | 02:31 PM
kflave12's Avatar
kflave12
1st Gear
Default brake lights and turn signals
My brake lights and turn signals go out at the same time intermittently. Seems like it is when I hit a rough spot in the road indicating a loose wire or connection. No other problems with the electical. Is there a specific connector/ground I can go to to check??
Old Jun 5, 2011 | 02:26 PM
0Stealth0's Avatar
0Stealth0
Sounds like a multifunction switch issue. I had the same problem. Turns out I had to swap out my turn signal lever for a new one.
Below is a process for trying to fix the one in the car. I tried this and it worked for a little but eventually I had to bite the bullet and buy a new one.
http://forums.corvetteforum.com/c5-t...f-replace.html
Old Jun 5, 2011 | 05:26 PM
jstrime's Avatar
jstrime
Check the wire harness bundle right below the steering column. I thought mine was the multifunctin switch, but it wasn't. Loose connections in the bundle below the steering column.
To brake lights and turn signals
