knocking sound when engine is cold
Old Apr 22, 2002 | 05:32 PM
00c5coupe's Avatar
00c5coupe
Default knocking sound when engine is cold
I think i heard some knocking sound (hard to hear) from the engine when i first started the car in the morning then drive it right a way. if i leave it run a about a min the drive it's ok. Any ideas? Thanks
Old Apr 22, 2002 | 06:02 PM
DsC5's Avatar
DsC5
Default Re: knocking sound when engine is cold (00c5coupe)
I've heard it's perfectly normal, don't really understand why though. Mine does it also, but only when cold. I think this has been discussed a few times - you can try a search. :seeya
Old Apr 22, 2002 | 06:28 PM
The Laplander's Avatar
The Laplander
Default Re: knocking sound when engine is cold (DsC5)
Perfectly normal? No way!
One or two cylinders are slightly overbored. (Factory error).
We are not so unlucky as the truck guys though, some of the engines in the trucks are really knocking and "dieseling".
The knocking will increase with the mileage..... :mad
But don´t expect GM to do anything about it, they will just say it´s "normal" and offer you an extended no-good warranty.
Old Apr 22, 2002 | 10:25 PM
DsC5's Avatar
DsC5
Default Re: knocking sound when engine is cold (The Laplander)
I'm not sure whether it's normal or not - notice I said "I've heard it's perfectly normal." Somebody with a greater technical understanding than me will have an explanation. :seeya
[Modified by DsC5, 9:25 PM 4/22/2002]
Old Apr 22, 2002 | 11:17 PM
Stilcrazee's Avatar
Stilcrazee
A month ago I bought a used 00 with 12,199 on it. Warranty till 05/03. It knocked 2 different times aftewr sitting overnight in garage..ambient temp about 50 degrees. Hadit going to dealer for minor things I found. Asked writer to check for knock...new pistons ad rings per Chevy. $3400. warranty. Run to dealer ask to have it checked, a buddy of mine works for GM out of Atlanta, I asked him and he replied that there are/were some bad rings and or pistons. Talk nice to he service writer.
He can check with mine, a really great guy at BILL KAY CHEVY, Lisle, IL. 630 968 2900 XT 3334..MARK BOWLING. They did all 8.
[Modified by Stilcrazee, 3:22 AM 4/23/2002]
Old Apr 23, 2002 | 02:22 PM
ersatz928's Avatar
ersatz928
Default Re: knocking sound when engine is cold (Stilcrazee)
The knock is caused by piston skirt slap, until the piston expands (heat) and the clearance decreases. Will it hurt anything in the long-run ? : probably not (pistons are softer aluminum, cylinder wall is a hard cast-iron liner), but it certainly doesn't enhance engine longevity or owner satisfaction!
Old Apr 23, 2002 | 04:10 PM
The Laplander
Default Re: knocking sound when engine is cold (ersatz928)
Well, check this out! http://www.angelfire.com/tx5/gmpistonslap/
Old Apr 23, 2002 | 10:57 PM
Corvette Poor's Avatar
Corvette Poor
This could also be caused by the type or brand of oil filter you use..Just a thought. Are you using the AC Delco ?
Old Apr 24, 2002 | 12:55 AM
Duck916's Avatar
Duck916
What year is your car? I believe around April of 2001 they started using the coated pistons to prevent piston slap. I know my car was produced after this running change and it is quiet.
Old Apr 24, 2002 | 01:20 AM
00c5coupe's Avatar
00c5coupe
Default Re: knocking sound when engine is cold (Duck916)
Thanks to all for your respond. My vette is a 2k model and had 24k miles. I don't remember hear this sound before but it wasn't that bad like the video above. I can hardly hear it (might be just me not the car...). I've been using different brand of oil filters, the one i have on the car is mobil 1. Will see if anything happen....
Thanks again.
Old Apr 24, 2002 | 02:16 AM
GLENN43's Avatar
GLENN43
I have a slite ticking when I start car in the AM after a few min. it go away .If I do not do any thing will there be any problems later on ? :flag :flag :flag
Glenn
To knocking sound when engine is cold
