Hud sunk
Old Jun 4, 2011 | 09:17 PM
ricknyc23's Avatar
ricknyc23
Default Hud sunk
Guys,
I think my HUD sunk a bit. I cant seem to raise it any higher. It lowers just fine but it seems lower than usual. An ideas on how to raise it?
Old Jun 5, 2011 | 08:09 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Sure it isn't your sitting position hasn't changed? Usually when they fail, they won't adjust up any more and the usual cause there is one of the pivot points inside has broken. If this is the case, you'll need to remove the dash pad cover to access, then get creative with repairing it.
Old Jun 5, 2011 | 04:19 PM
Chicago1's Avatar
Chicago1
If you do a search around here someone did awrite up on how to adjust it correctly. I know exactly what your talking about check the how to secion sticky at the top or hit the search.
Old Jun 6, 2011 | 08:45 AM
NealB's Avatar
NealB
http://forums.corvetteforum.com/c5-t...d-display.html
Old Jul 6, 2011 | 11:19 AM
ricknyc23's Avatar
ricknyc23
It's now sunk completely out of sight....
Old Jul 6, 2011 | 11:37 AM
dougbfresh's Avatar
dougbfresh
Broken tabs, search there is a hack to fix it.
To Hud sunk
