cracked rear leaf spring...help...
What are my options? C5 or C6 replacement spring? Repair the spring? I know that the spring is a composite material of some type.
I'm planning to do the C6 Z51 sways at the same time. The car is a DD/weekend toy but I'd like to stiffen it up for cornering and handling purposes.
Any help is much appreciated.
" I'm planning to do the C6 Z51 sways at the same time. The car is a DD/weekend toy but I'd like to stiffen it up for cornering and handling purposes. "That isn't possible.. Your either going to replace it with the same BASE spring (which will give you the same ride & handling) or up grade to a higher rate spring (which will allow you to drive the curves FLATTER) It will give you a little more firmer ride! Nothing bad!
My recommendations would be to:
Find a used C5 ZO6 spring, sway-bar and metal end link set up for front and rear OR call Gene Culley www.gmparthouse.com and get his C6 handling package with the C6 ZO6 Shocks! For the investment, you cant beat the significant improvement in handling!!
Your going to firm up the ride but the improvement in handling and surefootness of the car will put a smile on your face!!
Trust me,, I had a base suspension F-45 98 coupe. Got rid of that and got a ZO6!!
All I can say is,,,, Why the hell did I wait so long!!!!!!
With those up-grades, you will handle better than a stock C5 ZO6!
I added the C6 ZO6 shocks to my 02 ZO6 and the improvement in handling was significant!
I hated the ride of the 98!
BC
Mike C sends
Mike C sends
I'm sure that you will be extremely happy with the improvement!! I'm sure,, you will say to your self,, WOW,,Why did I wait so long to do this???
BC
Btw, changing the rear spring is a pretty easy job. Hand tools and a couple 6" C-clamps are all you need. The front spring is much more involved.
BTDT
BTDT
You are correct on the anti-roll bars. The Z51 bars are better (stiffer) than the "base" bars, but not as big as the C5 Z06 bars. For several years, most everyone upgrading was using the C5 Z06 bars and they are indeed better for cornering, etc and bolt right in. After the C6 was introduced, it became known that the C6 Z51 bars (not to be confused with C5 Z51) are actually bigger than C5 Z06 bars (though not by much), and also would bolt right up.
Btw, make sure to measure your ride height carefully before changing the rear spring. You can also mark your adjuster bolts as well to help get it back to where it was before you started. I would do both.
P.S. The reason I recommend 6" C-clamps, is that they are big enough to allow you to use wooden blocks to protect the new spring from damage when installing.
Mike C sends
Now I'm just waiting on verification of the spring(s) and a set of C6 Z06 shocks and I'll be set to go once I have them all here. Should be a fun afternoon.
I wonder how difficult the front sway bar will be to change out? It looks like it should be pretty easy from what I can see.
