For John or anyone else who can answer. Do the factory screens fit over the existing fog light shrouds or do you have to remove them? The main reason I'm asking is because I'm thinking of getting a pair of the fog shrouds from Ecklers (for a picture of the one I'm talking about, go to http://www.ecklers.com/product.asp?pf%5Fid=39186&dept%5Fid=1358 ).
Mostly, I was worried about the fog lights just dangling around inside the compartment, but I didn't want to cut into the existing shroud.
I bought the Z-06 screens, as well as the "opened up" fog lamp shrouds from Ecklers, as mentioned above. I haven't installed them yet, but I have done a "test fit", by placing the grill screens in the grill opening by hand and they fit just fine. This is with the stock fog lamp shrouds still on the car.
What I haven't yet determined is if the screens will be attached with screws or tape/velcro.
Jason, the screens fit perfectly !! I drilled holes in the stock backing instead of changing to the cold air screens. Just seemed like too much work involved to reach the same goal. I used doubole-edge tape, which is the best way to go.
