408ls2 queston???!?!?!?
Old Jun 7, 2011 | 06:50 PM
Dtownbrown's Avatar
Dtownbrown
Default 408ls2 queston???!?!?!?
I just bought an ls2 shortblock and dropped it off at the machine shop to get it built, queston is can I bore the aluminum block to a 408? I plan on making 800hp+ on the engine and wasn't sure if it would be safe? It is a FI setup and will be running around 15lbs of boost.
Old Jun 7, 2011 | 11:08 PM
chevylad's Avatar
chevylad
What are you calling a short block? I call a short block the bottom half of the engine already assembled, piston, rods and crank (no heads).
I don't believe you can bore an aluminum block, but you can have it honed. My LS2 402 has a 4.01 bore and a 4 inch stroke. I think that's on the safe side for a hone, but you can call one of vendor sponsors TSP and ask them about it.
Old Jun 8, 2011 | 02:52 AM
ZZ06's Avatar
ZZ06
and as far as i have seen, thats about as much as you can take the LS2. I believe the LS3 can acheive 418
Old Jun 8, 2011 | 07:54 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default LS2 + 4" crank = 402
To get 402" you will need a new crank. I would want new (Forged) internals to support 800+HP. Why not send it to ERL and get it sleved?
Bob K.
Old Jun 10, 2011 | 05:36 AM
ZZ06's Avatar
ZZ06
LS1/6 cranks can handle 1000hp. lol now if it were me id change it.....
Old Jun 10, 2011 | 07:09 AM
AU N EGL's Avatar
AU N EGL
But is very heavy too. Plus coated bearings would be nice for those power levels.
To 408ls2 queston???!?!?!?
