Crank Pulley Problem
Old Apr 22, 2002 | 10:00 PM
mill_yel-MR's Avatar
mill_yel-MR
Default Crank Pulley Problem
My local "Goodwrench Genius" informs me that the "locktite" type substance used on my crank pulley bolts has failed causing the pulley to walk off the crank creating the sqweal I've been experiencing. The really weird part of this is that it happened once before under high revs, causing the belt to walk off the pulley and partially shread itself. That was kinda nasty and resulted in a flatbed trip to GM.
I'm not a mechanic but I know that crank pulleys are torqued pretty high. What's wrong with this picture? A different dealer replaced the oil pump a little over a year ago shortly before the first incident. I think he must have snapped a bolt and these guys are covering up. Is this paranoid thinking on my part? The really frustrating part about this is they have had the car a week to figure this out.
I think a trip over to LS1.com is the next stop. Thanks for your help! :confused: :mad
Old Apr 23, 2002 | 01:48 AM
Paradigm's Avatar
Paradigm
Default Re: Crank Pulley Problem (mill_yel-MR)
The crank bolt is a stretch bolt and needs to be replaced with each swap of the harmonic. When I did mine, I bought two - one I used to tighten the harmonic into place with and then the other I used to torque and stretch properly.
Old Apr 23, 2002 | 11:31 AM
mill_yel-MR
Default Re: Crank Pulley Problem (Paradigm)
Thanks Paradigm, this gives me a little more info. and ammo. to discuss with the service manager. I still think that this should not happen twice!!
Old Apr 23, 2002 | 04:29 PM
B. Stewart's Avatar
B. Stewart
I had the same thing happen and it is a PITA! The buying the 2 bolts (mentioned above) idea is a good one. If you discover a reason please post it!
Old Apr 24, 2002 | 01:07 AM
mill_yel-MR
Default Re: Crank Pulley Problem Update(mill_yel-MR)
Dealer finished a weeks worth of work today. New belt, new center pulley bolt, stretched and locktite applied. Started the car in their driveway, squealed exactly the same as the day I drove it in. "These guys are good - NOT"
They did have the nerve to tell me the mechanic and service writer both drove the cars with no observed noise and gave me a half a** wash job.
:bs :cuss
Old Apr 24, 2002 | 01:50 PM
B. Stewart's Avatar
B. Stewart
Default Re: Crank Pulley Problem Update(mill_yel-MR) (mill_yel-MR)
When they replaced mine the dealer checked the runout and found a slight wobble. They replaced the harmonic balancer and pulley and the stretch bolt and pins. BTW no problems since. It's been almost 2 months.:yesnod:
[Modified by B. Stewart, 11:51 AM 4/24/2002]
To Crank Pulley Problem
