Coolant overflows ONLY when I stop!!! Help!!
Old Sep 4, 2011 | 12:34 AM
  #41
WICKEDFRC's Avatar
WICKEDFRC
I hope with all these recommendations you finally isolated and fixed the overheating issue. I know for sure, the center piece of the 3-Piece Spoiler helps reduce the temperature by directing air up and over the radiator. Sincr my center piece is missing (large rock in road took it out) I have noticed higher temps as well as one time over-heating where my temp gauge went in the red and my DIC warning came up. Pulled over and coolant started to boil over through reservoir tank. Since then, I haven't driven the Vette much, but have noticed a significant increase in temps without it, as high as 230 with a 160 Stat, and I don't dare use the A/C. Maybe this is or is not your issue, but the lower center piece surely makes a difference. And since it has been a while, I am going to consider a new 160 degree stat and coolant flush if I still see "higher" temps than normally seen.
Keep us posted. I am curious as to what the root of all your issues was.
Old Sep 4, 2011 | 11:35 AM
  #42
ssdungeon's Avatar
ssdungeon
What he said above!!!!
