Need add some freon
Old Jun 12, 2011 | 04:38 PM
Fear-This's Avatar
Fear-This
Default Need add some freon
Just bought a new to me 98 c5 been looking everywhere for repair manual cant seem find one. I need to add some freon to my low side ac service port looks like it's on the passanger side near the fire wall with a black cap. I need know if this is the corect location. Tks
Old Jun 12, 2011 | 05:29 PM
1986coupe's Avatar
1986coupe
Do a search on the forum. Some have posted links to software that contains the entire manual.
Or, purchase a FSM in book form.
Old Jun 12, 2011 | 05:32 PM
dougbfresh's Avatar
dougbfresh
If you use a GUAGE, you'll know the low pressure side. Most refill kits will only connect to the low side, the 2 ports are different sizes.
Old Jun 12, 2011 | 05:33 PM
69SSC5's Avatar
69SSC5
it should only fit the low side if its a R-134a refill tool/gauge
Old Jun 12, 2011 | 06:35 PM
chris308's Avatar
chris308
yes, the one by the battery. the high side is near the condenser.
Old Jun 12, 2011 | 06:52 PM
Chicago1's Avatar
Chicago1
Or you could use the search button and you can get a detailed how to..
Old Jun 12, 2011 | 07:03 PM
Fear-This's Avatar
Fear-This
Tks..
Old Jun 12, 2011 | 09:08 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Before you do the wrong thing, you can purchase a COMPLETE set of factory manuals from Gene Culley www.gmpartshouse.com
Here are some post to review:
- C5 AC System Service and Repairs: http://forums.corvetteforum.com/c5-g...post1570703001 ,, Rocco’s post http://forums.corvetteforum.com/c5-t...post1571637102
The AC line pressures are critical. You should also consider adding the correct oil charge before you add freon.
BC
Old Jun 12, 2011 | 09:59 PM
Carcass's Avatar
Carcass
If your A/C is low on gas,there's a leak somewhere,which really should be found and repaired,unless you just plan on adding freon every so often...
Old Jun 13, 2011 | 11:07 AM
Oldvetter's Avatar
Oldvetter
If you have a leak, the super sealer will work. The evaporators are terrible to access on these cars.
This is what I mean:
http://www.oreillyauto.com/site/c/de...1786&ppt=C0050
To Need add some freon
