Another Oil Pressure Sensor Nightmare..
Old Jun 12, 2011 | 04:47 PM
chuckster's Avatar
chuckster
Default Another Oil Pressure Sensor Nightmare..
Ok, my pressure sensor died and was pegged at the highest reading. I decide to forego the Oil Pressure Relocation.. I bit the bullet an went the standard route..
Pulled the intake.. cleaned up while in there.. Also I replaced the Intake Manifold Gaskets with a new set from Felpro ($21 at Autozone)
Put it all back together and change the oil.. Start it up.. I have very little pressure.. like 5lbs..
Take it for a drive and it goes to about 22lbs.. At wot it got to about 39ish.. As soon as I come back to idle it sets off the DIC with errors.. Oil Pressure Low like 5lbs
I am like MF MF MF CS CS CS GD GD GDMF MF MF CS CS CS GD GD GDMF MF MF CS CS CS GD GD GDMF MF MF CS CS CS GD GD GDMF MF MF CS CS CS GD GD GDMF MF MF CS CS CS GD GD GDMF MF MF CS CS CS GD GD GDMF MF MF CS CS CS GD GD GD
:wil ly:
I have to do this ALL OVER AGAIN!!!!
I guess it was the Piece of SCHIT sensor I bought on Ebay.. This was the Aluminum one..
Is it possible its just an air bubble or sonthin? will it work itself out? If not I am going to do the relocation mod this time..
Old Jun 12, 2011 | 05:03 PM
NatB's Avatar
NatB
Ouch - that's not good. Maybe check all the wiring to make sure it connected up right?
If I ever have to do mine - the relocation route sounds like the way to go to get that bugger out in plain sight.
Old Jun 12, 2011 | 05:14 PM
69SSC5's Avatar
69SSC5
i did the relocation mod... and it was very easy and worked like a charm.... but i wish i hadn't. I felt dirty afterward like i cheated, i will not cut my car again for a short cut
Old Jun 12, 2011 | 05:56 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Couldn't be that you bought it off of Ebay...has to be that cheap aluminum metal!
Old Jun 12, 2011 | 06:45 PM
lucky131969's Avatar
lucky131969
Hey Eric,
Unfortunately, GM did have a run of bad replacement sensors for some time. The replacements were made of aluminum, so that's where the association came from. Considering what is required to change the sensor, few guys elected to take the bad sensor back to the dealership parts department, and instead....ate the $60, and purchased aftermarket...Borg Warner, etc. As a result, GM had very little visibility of the bad sensors, and no initiative was enacted to quarantine the lot of material.
Old Jun 12, 2011 | 07:54 PM
chuckster's Avatar
chuckster
Hey dude long time.
Went for a ride tonight. Forthe first 10 minutes we had about 20 psi at idle and 30 at 2000 rpms. Then it dropped and dropped and set off the dic alarm. MFer!
Then parked the car went for a bite. Again it came back for a little then dies out.
That chime is maddening! It was better with the old sensor that read te highest reading and does not set off the errors. I need to fix this again!
Soooo what sensor can I rely on this time?????
Old Jun 12, 2011 | 08:01 PM
65GGvert's Avatar
65GGvert
Sounds like you did the cut a hole in the cowl method, not the relocation method. There's a big difference.
Old Jun 12, 2011 | 09:47 PM
Carcass's Avatar
Carcass
Hey dude long time.
Well,since you've got to go back in there,why not go with a relocation kit?
I just installed one from WCC-so next time it'll be a ten minute job.
The WCC unit also comes with a brass Buick sending unit-not sure if they're any better,but the one I just installed works like a charm...
You might think about changing the pass. side air check valve while you're in there - "fortunately" for me,the air check valve started throwing codes a week before the oil pressure sending unit took a dump,so I did them both @ the same time-air check valve is like ten bucks or so,and a ***** to change without pulling the intake.
Old Jun 12, 2011 | 10:19 PM
alankb's Avatar
alankb
Default O'Rieleys
I bought a brass one from O'Rieleys cheap, and for what it's worth, a lifetime garantee.
Old Jun 12, 2011 | 10:39 PM
Storm Cloud's Avatar
Storm Cloud
I also got a oil pressure sensor from O'Reillys that is used in Nascar (not sure what brand, but i think it's Borg Warner). Mine is working fine now and did not go with the cutting of the cowl. I went the long route and disconnected all the wiring, coolant lines to the throtle body and moved the intake out. I did keep the fuel line connected and just moved the intake over to the drivers side carefully. The thing that I forgot was putting the straw hose in back of the intake and kept getting a code. I had to take the whole intake off 3 times until I figured it out. If I ever have to change the oil pressure sensor again, I can do it very quickly now. Plus it allowed me to clean under the intake for excessive blowby.
Good Luck and I know you can fix it.
Old Jun 13, 2011 | 11:26 AM
chuckster's Avatar
chuckster
Yeah Lifetime is a waste..since the labor is the problem..
Old Jun 13, 2011 | 11:42 AM
johnson-rod's Avatar
johnson-rod
I bought one from Gene at GM Parts House. It's aluminum and has been working fine since January.
It replaced the original one from 1998. Apparently they knew how to make them at one time. Here's hoping they got it right again.
Old Jun 13, 2011 | 12:02 PM
VinnyT's Avatar
VinnyT
I lucked out and found 2 remaining brass ones at Advance Auto. Replaced over a year ago, no problems.
Old Jun 13, 2011 | 04:49 PM
chuckster's Avatar
chuckster
Went to the Dealer to get one today.. I told the guy about the crappy Mexico made Aluminum ones..
He brings me back..... An Aluminum one clearly marked made in mexico.. I said no thanks! Not going that route again..
Soooo.. Are all the aluminum ones bad? Where can I go to get a Reliable one? :
Old Jun 13, 2011 | 05:11 PM
lucky131969
No, they are not. I replaced mine 2 years ago, with an aluminum one....still going strong. Reality....you purchased yours from ebay. Which means someone probably bought them at a dealer auction(as is) for pennies on the dollar......because the dealer could not sell them. If a factory replacement scares you, then pick up a Borg Warner from Autozone, Advance, etc.
To Another Oil Pressure Sensor Nightmare..
