Sparco steering wheel install
Old Jun 12, 2011 | 10:56 PM
Joe_Planet's Avatar
Joe_Planet
Default Sparco steering wheel install
I installed a sparco steering wheel on a sparco hub. The hub slightly rubs the plastic housing, what can I do about it? Also the steering wheel is too far back and I'd like to get it closer to me by installing a quick release. Which one is good? I was looking for a sparco but cant find it anymore? Planning on trying on NRG 2.5 quick release, anyone have any experience with this?
Old Jun 13, 2011 | 08:17 PM
RX-Ben's Avatar
RX-Ben
The hub will grind down the plastic, you could sand it down if you want.
Old Jun 14, 2011 | 11:40 AM
Joe_Planet's Avatar
Joe_Planet
ok thanks.. i guess i'll just wait for the quick release and update the thread once i get it installed
Old Jun 26, 2011 | 08:29 PM
Joe_Planet's Avatar
Joe_Planet
so just a verbal update.
I got the NRG 2.5 quick release and installed it. Went incredibly smoothly and absolutely no play in quick release. Very satisfied with product, and the price was right at 120 vs sparco over 300.
This quick release is approximately 2.5" deep and it put the steering wheel in a perfect position as before it was way too far away from me and I was driving with my arms practically locked out. The horn works and I bypassed the airbag so I dont get a dash light.
Miso happy
Old Jun 26, 2011 | 09:00 PM
WKMCD's Avatar
WKMCD
Come on Dude...you cant do this to us.
How about some pics.
Old Jun 26, 2011 | 09:25 PM
TriplBlk's Avatar
TriplBlk
Deff needs pics.
Old Jun 26, 2011 | 10:53 PM
Joe_Planet's Avatar
Joe_Planet
Guys, I do apologize... coz i'm a lazy bastid..
I'll post some tomorra... probably
Old Jun 27, 2011 | 05:08 PM
sbadd99's Avatar
sbadd99
probaly, thats slack come on
Old Jun 27, 2011 | 06:34 PM
WKMCD's Avatar
WKMCD
It's tomorra...
Old Jun 27, 2011 | 06:50 PM
TriplBlk's Avatar
TriplBlk
He's prolly bizy with otha Gahbage. Lil bastid...
Old Jun 27, 2011 | 09:08 PM
Joe_Planet's Avatar
Joe_Planet
Old Jun 27, 2011 | 09:17 PM
Joe_Planet's Avatar
Joe_Planet
i couldnt figure out how to make them full size
imageshack you suck, what a PITA
enjoy!
Old Jun 27, 2011 | 10:03 PM
TriplBlk's Avatar
TriplBlk
What hub did you go with? I have the Sparco Ring
Old Jun 27, 2011 | 11:01 PM
Joe_Planet's Avatar
Joe_Planet
I used the sparco hub, it was around $70.. reasonably priced.
One thing I wish I would have done is removed a little bit of material with a drill press so the horn wire would clear better, but alas I havent a drill press. Also I should have used some sand paper to thin out the inside of the column enclosure.. because currently the hub rubs on it, but every time I make a turn I get a little more clearance
Old Jun 28, 2011 | 06:38 AM
WKMCD's Avatar
WKMCD
Very Nice!
Old Jun 28, 2011 | 07:56 AM
argonaut's Avatar
argonaut
Any chance you could post a full list of the parts, part numbers and where you got them from? I'd love to do this next winter. Thanks.
Old Jun 28, 2011 | 01:24 PM
Joe_Planet's Avatar
Joe_Planet
Got most parts from amazon.com
sparco steering wheel hub. lists for jeep but also works on gm.
sparco 383 suede steering wheel. universal.
nrg ver 2.5 quick release hub. universal. (dont see any problems using any other of their quick releases)
2 ohm 5 watt resistor also from amazon.
extra clock spring from vette nuts so you can cut off the connector and solder in the resistor to simulate airbag.
female and male insulated spade terminals from radio shack to crimp to wires and make horn work
beer
To Sparco steering wheel install
Old Jun 29, 2011 | 07:32 AM
jrmotorsports55's Avatar
jrmotorsports55
Very nice. I hate the stock c5 wheel.
Old Jul 2, 2011 | 02:26 AM
eagle01's Avatar
eagle01
Default removing factory steering wheel
can you also post how you took out the factory steering wheel (with details if possible, like tools to use, etc) and especially how you disabled the airbag; that is a cool looking setup you got there!
Old Jul 2, 2011 | 07:40 AM
Joe_Planet's Avatar
Joe_Planet
there are diy posts, but i can give a quick description
remove center console
remove knee bolster
remove airbag by unscrewing 2 torx screws on the back of airbag
remove steering wheel with steering wheel puller
remove steering column shroud
remove clock spring you wont need it anymore
plug in your fabricated airbag bypass connector by fabricating it from a clock spring connector that you cut off and soldered the resistor to (either use yours or purchase extra.
install hub
install quick release
wire up horn to quick release
install steering wheel
wire up horn button
beer
cigarette
enjoy!
