Cabin filter, location & removal
Old Jun 14, 2011 | 04:32 PM
White Heat's Avatar
White Heat
3rd Gear
Default Cabin filter, location & removal
Having that strange foul odor that is possibly coming from the cabin filter. Unable to find it. Maybe the C5 didn't come with a cabin filter. However, I doubt that. Thxs everyone.
Old Jun 14, 2011 | 04:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NO FILTER ON A C5!!! Look at the well under the wiper motor. There are THREE UDDERS in that well that plug up and FOUL NASTY water build up and stinks to high heaven!
You can reach the udders here:
They POP IN and OUT easily! Make sure that theres no decaying crap in the well..
BC
Old Jun 14, 2011 | 05:55 PM
White Heat's Avatar
White Heat
3rd Gear
Thank you guys and thanks for those pics and links.
Pat
Old Jun 15, 2011 | 08:19 AM
brrymnvette's Avatar
brrymnvette
Thanks Bill! I was just looking for this!
Old Jun 15, 2011 | 08:46 AM
99 vett babycar's Avatar
99 vett babycar
the odor can also be comming from your AC ducts ( mildew). Any auto supply will have a product ( brand names vary) that you can spray into the vents to eliminate the odor.
Old Jun 15, 2011 | 08:49 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by hotwheels57
If you've got that stale smell coming from your vents, there is an aerosol product (GM or after market) that you spray into the vents. It's supposed to be pretty effective.
Lysol spray works good too.
Old Jun 15, 2011 | 10:26 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% correct! That is another area where moldey smells can originate.
Make sure that the HVAC Condensate Drain on the fire wall is free and clear and allows the condensation that builds up in the AIR BOX to drip out of the air box!
If you dont see water driping out of the car when the AC is on and running, you either live in a state with ZERO humidity or the drain is clogged!!
BC
Old Jun 15, 2011 | 11:24 AM
rebelheart's Avatar
rebelheart
We use a mopar product to kill the mold that forms on the evap core for this problem.I think most parts stores sell a product call frigidfresh that is the same thing.You spray it into the recirc door to coat the core,it works!
Old Dec 31, 2012 | 06:27 AM
nnicholas's Avatar
nnicholas
I have a 2001 Corvette Convertible and have a moisture problem where the inside widows and the inside trunk lid have water that forms on the inside. Is that normal because it is a convertible?
Nick
Old Dec 31, 2012 | 07:56 AM
65GGvert's Avatar
65GGvert
You just tacked a new question on the end of a year and a half old thread about a non-existant cabin filter. To get better answers, click "start new thread" instead of "reply". (also violates forum rules about posting on a thread older than 45 days with no activity) I see you just joined, so thought I'd give you an FYI.
I can tell you however that I have owned 3 C5 convertibles and I've never seen any condensation inside the car or trunk. You may have a drain blocked in the a/c where it goes through the firewall letting water back up into the cabin.
Old Dec 31, 2012 | 09:20 AM
nnicholas's Avatar
nnicholas
I appologize for this and will not do it again..
Sorry!
Nick
Old Dec 31, 2012 | 09:33 AM
65GGvert's Avatar
65GGvert
Sorry!
Nick
No need to apologize. I'm sorry if it sounded like you needed to. I wanted to be helpful since you are new and explain the best way to get fresh relevant information. Many times when you add on to an old thread, specially when your question is different, you don't get the answer you're looking for. It's best to do "new thread" and put words in the title of the thread that get you answers and that you and others can "search" later. That's why it's in the rules to not post in threads with no responses in over 45 days. There's a whole page of rules, and they are often not followed, but can cause the thread to be locked by moderators. That will also stop the responses that you may need to solve your issues.
Old Dec 31, 2012 | 09:38 AM
nnicholas's Avatar
nnicholas
Thank you very much for this information. I am overwhelmed with the amount of information provided by this forum. I have about 5 different issues I need to work on pertaining to my C5. I should have my garage cleaned out to the point I can get my car inside to work on these issues. Love your 65 Vette, Sweet Ride
Nick
Old Dec 31, 2012 | 11:01 AM
65GGvert's Avatar
65GGvert
Thank you. When you post a new thread, put the problem in the title, that way someone who has had the problem can see it and click to help. Also, in the future searches, it will show up for someone else having the same problem. Also put in your question the year of your car and whether it's manual or auto, body type, etc because all systems aren't equal between all C5's. I would bet that any issue you have has been seen before and someone will know the answer. Lots of people on here willing to help.
Old Dec 31, 2012 | 11:07 AM
nnicholas's Avatar
nnicholas
I will learn how to post correctly the more I get into it. I really do appreciate the help...Nick
Old Dec 31, 2012 | 12:36 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Nick
Water inside a c5 is NOT normal. You have a leak,, find and fix it,
BC
Old Dec 31, 2012 | 01:44 PM
nnicholas's Avatar
nnicholas
What I did find out is before the car was sold the back window was busted out and replaced. I do not know how long the window was out before it was fixed. The moisture could have been in there prior to and gotten down into the padding. If that's the case I will deffinetly have to take the carpets out and replace the padding. I have a new convertible top to install anyway....
To Cabin filter, location & removal
Old Nov 15, 2016 | 11:15 PM
tondelayo's Avatar
tondelayo
Default Hint as to where this is on the vehicle?
BC
"on the firewall" -- OK, any hint as to where on the firewall? Driver's side, passenger side, accessed from above, accessed from below?
Thanks,
Sal
Old Nov 16, 2016 | 11:26 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL! Passengers Side... Look at the rear of the passengers head. There will be a lip area on the fire wall near the area where the head sits on the block. That boot /fitting is in that lip area.
Tough to get to from above and if you have headers, it makes the job tough also from below.
Old Nov 16, 2016 | 11:36 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Passengers side rear of engine behind/under the big engine wire harness:
