Horn issue
Old Jun 19, 2011 | 11:15 AM
8birds's Avatar
8birds
Default Horn issue
My horn stopped working in my 99 convert. I'd don't honk much except when in parking lots and I see backup lights come on, but horn is tied into alarm system and needed to pass inspection. Dealer says this is a $900 fix since the horn is tied into the air bag. I'm stunned. Is there a work around for this? thanks, 8birds
Old Jun 19, 2011 | 12:52 PM
lucky131969's Avatar
lucky131969
Any troubleshooting done? That's a bold estimate, if they are just assuming the membrane is bad...
Old Jun 21, 2011 | 09:17 PM
8birds's Avatar
8birds
Thanks. Got a second opinion. Same as first. I'm thinking it over. Tom
Old Jun 22, 2011 | 01:07 PM
ShootCraps's Avatar
ShootCraps
Both of my horns went bad. thought it was the membrane switch so I replaced it and they still didn't work. Put 12volts DC on your horns and see if they work. Also, can you hear the relay click when you press the horn button? If it is your membrane I can sell you one cheap. It's very easy to replace the switch.
To Horn issue
