regular vs breather catch can???
Old Jun 19, 2011 | 11:33 AM
FLYNAVY30's Avatar
FLYNAVY30
Default regular vs breather catch can???
Im about to order a PCV catch can from forum vendor CCA, any opinions on the regular vs the vented can with the breather on top that eliminates the line running to the intake?? Ideally Id like to run the one with the breather and eliminate that line but wanted to know if there is any downside to doing that.
Old Jun 20, 2011 | 01:11 AM
avenger88's Avatar
avenger88
^^^same boat .. also lookin for answer
Old Jun 20, 2011 | 05:13 AM
vettenuts's Avatar
vettenuts
That doesn't appear to me to fit the bill as a PCV setup, i.e., positive crankcase ventilation. You are now relying on internal blowby pressure buildup to vent the crankcase at all RPM. I would think cold start condensation purge wouldn't be as effective either.
If it were my car, I would go with the non-vented and keep the connection to the intake.
Old Jun 20, 2011 | 04:28 PM
FLYNAVY30's Avatar
FLYNAVY30
makes sense, thanks
Old Jun 20, 2011 | 06:57 PM
Last C5's Avatar
Last C5
Vettenuts,
I'm running a conventional non-breather catch can from the valley to the PCV/Intake behind the throttle body
AND
A breather catch can off the passenger side valve cover, thereby deleting the tube to the front of the intake ahead of the throttle body.
This is on a track car and it seems to be working fine. Am I missing something (or will I be), just looking for your take on this set up.
Doug - Last C5
Old Jun 20, 2011 | 07:40 PM
StingrayRebel's Avatar
StingrayRebel
... i wouldn't run one with a breather either... the pcv also helps remove condensation as stated above and with this removed will cause sludge to build up faster than normal... i guess it may not be a problem if you change your oil like you do underwear but who really does that??
Old Jun 20, 2011 | 10:12 PM
SaberD's Avatar
SaberD
use that intake vacuum to help out the pcv system. it doesn't make sense to remove something that gives the system an advantage. that's why they designed it the way they did.
Old Jun 21, 2011 | 10:15 AM
waddisme's Avatar
waddisme
Originally Posted by Last C5
Vettenuts,
AND
Doug - Last C5
Same here.
Old Jun 24, 2011 | 12:03 PM
Last C5's Avatar
Last C5
Anybody????
To regular vs breather catch can???
