2:73 to 3:42
Old Jun 19, 2011 | 03:39 PM
david1st's Avatar
david1st
Default 2:73 to 3:42
Need advice....how difficult is it to swap 2:73 to 3:42 gears? Any diy threads?
Old Jun 19, 2011 | 04:09 PM
wascapsfan's Avatar
wascapsfan
If you have a manual there are slightly different instructions for that.
Differential Replacement Automatic Transmission
Removal Procedure
Object Number: 321407 Size: SH
Click here for detailed picture of above image.
Notice
Failure to follow the proper removal and installation procedures may result in damage to the engine crankshaft thrust bearing.
Notice
When tilting down the rear of the driveline, observe the clearance between the rear of the engine and the composite dash panel. Do not allow the engine to rest unsupported against the composite dash panel, or vehicle damage may result.
Notice
When lowering and removing the rear of the driveline, observe the clearance between the rear of the transaxle assembly and the underbody to prevent damage.
Tools Required
J 42055 Transmission Support Fixture
Object Number: 180595 Size: SH
Caution
Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
Disconnect the negative battery cable.
Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the rear tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Remove the intermediate exhaust pipe. Refer to Intermediate Pipe Replacement in Engine Exhaust.
Tie off the LH muffler assembly to the underbody to support the muffler out of the way.
Remove the RH muffler assembly. Refer to Muffler Replacement in Engine Exhaust.
Remove the driveline tunnel closeout panel. Refer to Driveline Tunnel Closeout Panel Replacement in Propeller Shaft.
Object Number: 173638 Size: SH
Remove the two plug bolts from the front of driveline support assembly.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Important
The propeller input shaft front bearing positioning bolts are intended to remain torqued to specification and in place UNTIL INSTRUCTED in the installation procedure.
Important
Failure to use the minimum length fastener specified will prevent proper retention of the propeller input shaft front bearing during disassembly or installation.
Install two bolts, M10 - 1.5 X 55 mm, or longer, in place of the plug bolts.
(The long bolts are located to maintain the propeller input shaft front bearing in original position during removal and installation.) Tighten
Tighten the propeller input shaft front bearing positioning bolts to 35 N·m (26 lb ft).
Object Number: 71455 Size: SH
Using a flat bladed screwdriver, remove the engine flywheel housing access plug.
Object Number: 173641 Size: SH
Loosen the propeller shaft hub clamp bolt (1).
Rotate the engine at the flywheel, if necessary for alignment.
Object Number: 71443 Size: SH
Remove the nuts retaining the transmission shift cable bracket to the transmission.
Object Number: 173669 Size: SH
Disconnect the transmission shift control cable from the transmission shift lever.
Unsnap to release the cable.
Reposition the transmission shift cable and bracket.
Object Number: 180606 Size: SH
Remove the rear transverse spring. Refer to Rear Transverse Spring Replacement in Rear Suspension.
Support the lower control arm with a straight jack.
Disconnect the outer tie rod end from the suspension knuckle. Refer to Tie Rod Replacement in Rear Suspension.
Remove the shock absorber lower mounting bolt.
Disconnect the lower ball joint from the suspension knuckle. Refer to Knuckle Replacement in Rear Suspension.
Remove the straight jack from the control arm.
Repeat steps 18 through 22 for the other side of the vehicle.
Object Number: 196197 Size: SH
Assemble the J 42055 .
Install the J 42055 to a transmission jack.
Position and firmly secure the J 42055 with the transmission jack to the transmission.
Object Number: 180633 Size: SH
Disconnect the wiring harness and brake pipe clip retainers from the rear suspension crossmember.
Remove the differential to transmission lower nut.
(Removing the nut at this time will aid in separating the differential from the transmission after the driveline has been removed from the vehicle.)
Remove the transaxle mount to rear crossmember nuts.
Object Number: 180637 Size: SH
Position a transmission jack under the rear suspension crossmember and firmly secure the crossmember to the jack.
Using ONLY HAND TOOLS, remove the rear suspension crossmember retaining nuts.
Object Number: 180638 Size: SH
With the aid of an assistant, slowly lower the rear suspension crossmember away from the vehicle frame rails and remove the crossmember.
Object Number: 71501 Size: SH
Remove the transaxle mount bracket to differential bolts.
Remove the transaxle mount with bracket.
(Removing the transaxle mount will allow for greater stability on a workbench after the driveline is removed.)
Object Number: 196201 Size: SH
Using a pry bar, CAREFULLY release the axle shafts from the differential.
Tie off the axle shafts to the underbody to support the shafts out of the way.
The LH muffler assembly pipe toward the rear offers a good location to help support the LH axle shaft (1).
Object Number: 71407 Size: SH
Release the retainer (1) securing (and positioning) the wiring harness to the L-shaped brackets along the driveline support assembly, then slide the harness up out of the brackets and position out of the way.
Object Number: 180649 Size: SH
SLOWLY lower the driveline approximately 5 cm (2 in), while simultaneously adjusting the angle of tilt, in order to access the electrical connectors.
Disconnect the vehicle speed sensor (VSS) electrical connector.
Object Number: 71409 Size: SH
Disconnect the wiring harness retainer from the stud at the differential rear cover.
Disconnect the wiring harness retainer clip from the top of the differential.
Object Number: 173659 Size: SH
Disconnect the transmission harness 20-way connector.
Depress both tabs on the connector and pull straight up; do not pry the connector.
Object Number: 205288 Size: SH
Disconnect the park/neutral position switch electrical connectors.
Remove the bolt retaining the transmission wiring harness to the LH side of the transmission case.
Object Number: 196198 Size: SH
SLOWLY lower the driveline, while simultaneously adjusting the angle of tilt, and observe the relationship between the top rear of the differential and the lowest part of the rear compartment panel floor (the center storage compartment between the frame rails); the differential should not be lowered more than approximately EVEN with the specified body point of reference.
(The engine positive crankcase ventilation (PCV) pipes which route along the rear of the engine intake manifold will likely contact the dash panel.)
Release the wiring harness from the harness retainer along the top of the transmission.
Check to be sure that the wiring harness is free from the driveline being removed.
Object Number: 71418 Size: SH
Disconnect the transmission oil cooler rear pipes from the junction fittings at the engine flywheel housing, then cap the pipes and plug the junction fittings to prevent contamination.
Object Number: 196199 Size: SH
Using a block of wood to protect the engine oil pan, place a straight jack under the rear of the engine oil pan to support the engine from stressing the composite dash panel.
Remove the five driveline support assembly to engine flywheel housing bolts.
Object Number: 71406 Size: SH
Carefully bend the wiring harness bracket away from the driveline, toward the driveline tunnel wall in order to make a clear removal path for the driveline.
Object Number: 196200 Size: SH
Important
The aid of an assistant will be necessary for the remaining steps.
Have an assistant insert a flat bladed screwdriver, or similar tool, between the edge of the driveline support assembly and the engine flywheel housing, then begin to pry the driveline loose from the engine.
Object Number: 71466 Size: SH
Have an assistant guide the front of the driveline during the removal of the driveline from the vehicle.
SLOWLY lower the driveline, while simultaneously adjusting the angle of tilt and pulling the driveline away from the engine UNTIL the propeller input shaft at the front of the driveline support assembly just clears the engine flywheel housing.
SLOWLY lower the driveline completely out of the vehicle.
Object Number: 196196 Size: SH
Position the chainfall, or equivalent, of a lift device in a way which will protect the transmission oil cooler rear pipes and the rear exhaust hangers located on the driveline support assembly.
Using the lift device, raise the driveline to relieve the weight from the transmission jack.
Disconnect the J 42055 from the transmission jack ONLY, the J 42055 will provide stability to the driveline components while working on a bench.
Position the driveline on a workbench with the lift device still attached.
Support the driveline support assembly and the differential for additional balance.
Remove the lift device from the driveline.
Object Number: 71505 Size: SH
Remove the differential to transmission bolts and nuts.
Important
Use care when separating the differential from the transmission to not damage the transmission output shaft seal in the differential plate.
SLOWLY slide the differential from the transmission.
Object Number: 71504 Size: SH
Remove the differential plate from the differential.
Installation Procedure
Notice
Tools Required
Object Number: 194916 Size: SH
Install the differential plate to the transmission, use care not to damage the transmission output seal in the rear of the plate.
Position the square-lip differential plate seal flush with the transmission case.
SLOWLY slide the differential to the transmission.
Notice
Install the differential to transmission bolts and nuts.
Tighten
Tighten the differential to transmission bolts and nuts to 50 N·m (37 lb ft).
Important
The aid of an assistant will be necessary for the following steps until the driveline is installed into the vehicle.
Using the lift device, raise the driveline off the workbench and position the driveline with the J 42055 onto a transmission jack.
Connect the J 42055 to the transmission jack.
Position the driveline under the vehicle.
Begin to raise the driveline at the approximate angle used during removal.
Position the wiring harness along the driveline support assembly and LOOSELY install the harness into the harness retaining slots.
Have an assistant guide the front of the driveline so the propeller input shaft is just to the rear of the engine flywheel housing, then raise the driveline to the PROPER HEIGHT and the PROPER ANGLE to install to the engine.
Important
Use care not to use too much force to install the propeller input shaft into the propeller shaft hub. The propeller input shaft front bearing positioning system is designed to withstand an insertion force not greater than 582 N (130 lb).
Have an assistant begin to insert the propeller input shaft into the propeller shaft hub while maintaining the proper angle of the driveline, if necessary use a screwdriver to rotate the shaft slightly to bring the splines into alignment.
SLOWLY seat the driveline to the engine flywheel housing while maintaining the proper angle of the driveline.
Reposition the wiring harness bracket from near the driveline tunnel wall to align with the appropriate driveline support assembly bolt hole.
Install the five driveline support assembly to engine flywheel housing bolts.
Tighten
Tighten the driveline support assembly to engine flywheel housing bolts to 50 N·m (37 lb ft).
Install the wiring harness to the wiring harness retainer along the top of the transmission.
SLOWLY raise the driveline to approximately 5 cm (2 in) BELOW the final installed height.
Remove the caps from the transmission oil cooler rear pipes and remove the plugs from the junction fittings at the engine flywheel housing.
ALIGN and HAND-START, then tighten ONLY by hand to seat the transmission oil cooler rear pipes to the junction fittings at the engine flywheel housing.
Tighten
Tighten the transmission oil cooler rear pipes to junction fittings at engine flywheel housing to 27 N·m (20 lb ft).
Install the transmission wiring harness to LH side of transmission case retaining bolt.
Tighten
Tighten the transmission wiring harness to LH side of transmission case retaining bolt to 2.5 N·m (22 lb in).
Connect the park/neutral position switch electrical connectors.
Object Number: 173661 Size: SH
Connect the transmission harness 20-way connector.
Align the arrows on each half of the connector and insert straight down.
Connect the wiring harness clip to the top of the differential.
Connect the wiring harness retainer to the stud at the differential rear cover.
Connect the vehicle speed sensor (VSS) electrical connector.
Slowly raise the driveline to final installation height.
Remove the jack which supported the engine.
Remove the tie-off retainers from the axle shafts.
CAREFULLY align and seat the axle shafts to the differential.
Install the transaxle mount and bracket to the differential.
Install the transaxle mount bracket to differential bolts.
Tighten
Tighten the transaxle mount bracket to differential bolts to 50 N·m (37 lb ft).
With the aid of an assistant, begin to raise the rear suspension crossmember (still firmly attached to a transmission jack), to the vehicle frame rails.
Guide the rear suspension crossmember alignment pins into the alignment holes in the vehicle frame rails, and guide the transaxle mount studs into the mounting holes in the crossmember, then raise the crossmember to seat to the frame rails.
Using ONLY HAND TOOLS, install NEW rear suspension crossmember mounting nuts.
Tighten
Tighten the rear suspension crossmember mounting nuts to 110 N·m (81 lb ft).
Remove the transmission jack from the rear suspension crossmember.
Release the J 42055 from the transmission, then remove the J 42055 and transmission jack.
Install the transaxle mount to rear suspension crossmember nuts.
Tighten
Tighten the transaxle mount to rear suspension crossmember nuts to 50 N·m (37 lb ft).
Install the differential to transmission lower nut.
Tighten
Tighten the differential to transmission lower nut to 50 N·m (37 lb ft).
Connect the wiring harness and brake pipe clip retainers to the rear suspension crossmember.
Connect the lower ball joint to the suspension knuckle. Refer to Knuckle Replacement in Rear Suspension.
Install the shock absorber lower mounting bolt.
Tighten
Tighten the rear shock absorber lower mounting bolt to 220 N·m (162 lb ft).
Connect the outer tie rod end to the suspension knuckle. Refer to Tie Rod Replacement in Rear Suspension.
Remove the straight jack from the suspension control arm.
Repeat steps 40 through 44 for the other side of the vehicle.
Install the rear transverse spring. Refer to Rear Transverse Spring Replacement in Rear Suspension.
Carefully pull the wiring harness down into the L-shaped brackets along the driveline support assembly, align the harness retainer (locator) (1) to the hole in the forward bracket, then secure in place.
Install the transmission shift cable and bracket into position.
Connect the transmission shift cable to the transmission shift lever.
Press to secure the cable.
Install the nuts retaining the transmission shift cable bracket to the transmission.
Tighten
Tighten the transmission shift cable bracket retaining nuts to 20 N·m (15 lb ft).
HAND-TIGHTEN the propeller shaft hub clamp bolt (1) until FINGER-TIGHT.
Remove the propeller input shaft front bearing positioning bolts (M10 - 1.5 X 55 mm) from the driveline support assembly.
Install the two plug bolts to the front of the driveline support assembly.
Tighten
Tighten the driveline support assembly front plug bolts to 50 N·m (37 lb ft).
Install the driveline tunnel closeout panel. Refer to Driveline Tunnel Closeout Panel Replacement in Propeller Shaft.
Remove the tie-off retainer from the LH muffler assembly.
Install the RH muffler assembly. Refer to Muffler Replacement in Engine Exhaust.
Install the exhaust intermediate pipe. Refer to Intermediate Pipe Replacement in Engine Exhaust.
Install the rear tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Lower the vehicle.
Connect the negative battery cable.
Tighten
Tighten the negative battery cable bolt to 15 N·m (11 lb ft).
Program the transmitters. Refer to Transmitter Programming/Synchronization in Keyless Entry.
Important
The following steps MUST be performed in order to provide proper alignment of the propeller shaft hub, the propeller input shaft and the propeller input shaft front bearing.
Start and run the engine at idle until normal operating temperatures are reached.
(Idle or drive for at least 10 minutes.)
Turn off the engine and allow the powertrain to cool to ROOM temperature.
Raise the vehicle.
Tighten the propeller shaft hub clamp bolt (1).
Tighten
Tighten the propeller shaft hub clamp bolt to 130 N·m (96 lb ft).
Install the engine flywheel housing access plug.
Flush the transmission oil cooler. Refer to Automatic Transmission Oil Cooler Flushing and Flow Test in Automatic Transmission.
Lower the vehicle.
Document ID# 423664
1999 Chevrolet/Geo Corvette
1G1YY
Old Jun 19, 2011 | 04:58 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
buy a new c5 Z06 diff with the 3.42 gears in it already then just swap the carriers.
You will also need to get your shift points changed.
Old Jun 19, 2011 | 05:59 PM
david1st's Avatar
david1st
IS IT A SIMPLE SWAP? I HAVE A PROGRAMER TO GHANGE SHIFT
POINTS
Old Jun 20, 2011 | 04:16 PM
GeneT's Avatar
GeneT
Removal Procedure.........etc. etc.......
Lower the vehicle.
Document ID# 423664
1G1YY
Now that sounds like a fun evening in the garage
Old Jun 20, 2011 | 05:24 PM
ALVETTE00's Avatar
ALVETTE00
Agree with Weasel
Don't try to swap the ring&pinion, a stock 3xx gear won't fit into a stock 2-series carrier.
Old Jul 16, 2012 | 04:35 PM
kha4079's Avatar
kha4079
Originally Posted by ALVETTE00
Agree with Weasel
can all you guys answer why it wont change all i read is recommendations i would like to know why it doesnt fit THATS THE ONLY QUESTION ASKED ON 99.9% OF THESE THREADS!
Old Jul 16, 2012 | 05:00 PM
chaase's Avatar
chaase
St. Jude Donor '12
The carrier is too small. The 3.xxx series gears are too big to fit in the 2.73 carrier. It has been covered many times and you are not supposed to open back up 1 year old threads.
Old Jul 16, 2012 | 09:42 PM
DIXZ's Avatar
DIXZ
Sinceyouarretolazytocapitolizeorusepunct uation,Iwillnotusespacestoanswer.
TheproblemistheVSS.Itislocatedinadiffere ntpositiononthe2.73differential.Youcange taftermarketgearstowork,butIamonlyawareo f3.90and4.10gears!Bestofluck!
Old Jul 17, 2012 | 12:16 AM
NukeC5's Avatar
NukeC5
I did this mod. Just do a complete carrier unit. It works just fine and only takes a quick tune. I would stay away from a mail-order chip. Get a professional tune. The Superchip I originally went with didnt get the shift points right and made me redline constantly.
Old Jul 17, 2012 | 01:13 AM
RonSSNova's Avatar
RonSSNova
Someone with HPT can do it in 5 minutes for you.
I did mine, and the new shift points are just fine.
Or, you can move them up a little if you like.
Easy peasy.
Ron
To 2:73 to 3:42
