Cloynes double roller timing chain crank position sensor problem
i have a Cloynes double roller timing chain in a LS2 but now i get no impulse from the crank position sensor. I ordered the AC Delco 12560228 but it is too long. Also the check mark from the double roller is on the front but i think on the position sensor it is sidewise?
The lenght from the cover to the timing chain is 1,02 inches, so i think the sensor should be about 0,98 inch. The diameter is now 0,78 inch but would be better 0,62-0,66 inch because otherwise we have to file the corner.
Please could you give me a part number that fits with the Corvette harnesses. steve
