PILOT BEARING REPLACEMENT...do it or not?
It states: If pilot bearings and throwout bearings are good and not replaced, One week after the new clutch is in, the old stuff will fail.
Murphys Law# 32756 states that the components, when they fail, will fail when your 300 + miles from home!
If it were me,,,,,,,, I would replace it!
NOTE! DO NOT let the weight of the Torque Tube/Trans/Differential droop on the clutch disk or pilot bearing!
BC
BC
I know what you mean. This is my second install in the last three weeks. I did one on a buddies car and now my CLUTCH took a dump and here goes mine...of course, my ride is modded, his was not with half the miles. NAVET on a boat, never owned a manual and learned the hard way.
I appreciate it.
Micah
"DO NOT DO IT!!!!!!!"
Same thing for grease!
The Crankshaft in an LS engine is hollow. The end of the crank contains a WELSH PLUG (like a freeze plug) that is pressed into the recess to seal the oil from leaking out of the crank into the bell housing.
IF you use that trick to remove the pilot bearing, it is highly likely and very possible that you will unseat that plug and have a massive oil in the crank to bell housing leak!!!
BC
BC
Is that what that puddle in my floor is???
I have done it multiple times with no issue, granted I didnt slam bread into my crank with a sledge hammer. But seriously I have had no issues doing it that way but heard the same thing when I posted about doing it.
(Has to be huge) snap ring pliers.
Thanx!
BC
Had to use bigger slide hammer.
But I get hungry in the garage and the two just go hand in hand... have a sandwich and remove the pilot bearing with the leftovers...
