another squeaky belt problem
Old Jun 20, 2011 | 07:27 PM
donaldmiller_69's Avatar
donaldmiller_69
Default another squeaky belt problem
Got a 98. Just replaced the belts and the ac idler pulley. What else could be doing it? Only squeaks when its under acceleration. Any ideas would be great. Thank you
Old Jun 21, 2011 | 10:58 AM
ShootCraps's Avatar
ShootCraps
The alternator pulley. Have someone rev it and watch that pulley.
Old Jun 25, 2011 | 01:01 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
did you remove the ac belt first then see if the problem was gone before replacing it?
you replaced the ac tensioner pulley already, when you did this did you only replace the pulley or the entire tensioner bracket?
The bracket itself can be a source of noise. I would first rule out the squeak by removing the belt to determine what system it is coming from.
Use the search function on the forum to find more details.
It is possible it is your idler tensioner pulley or even an issue with your crankshaft pulley if it is wobbling.
Old Jun 25, 2011 | 08:55 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
SEARCH is your friend...Ive posted to this issue countless times.. read my comments and tips in the link below
http://forums.corvetteforum.com/c5-g...er-rattle.html
Old Jun 26, 2011 | 03:29 PM
donaldmiller_69
Replaced both belts, ac idler and belt tensioner. Still squeals. Sprayed water on the serp belt and it stopped the squealing. Ordered a gatorback belt from summit today. I think I had a dayco on it then a duralast. Hopefully the gatorback fixes my problem.
Old Jun 26, 2011 | 08:22 PM
Evil-Twin's Avatar
Evil-Twin
Its always best to just throw money at a problem in the hope that sooner or later you will replace enough good parts until you finally replace everything. Glad I offered you the correct procedure to isolate this problem.
To another squeaky belt problem
