changing rotors...what to do w/ current pads
Old Jun 22, 2011 | 04:27 PM
MStrahan's Avatar
MStrahan
Default changing rotors...what to do w/ current pads
I'm going with new rims and tires shortly and would like to upgrade my brakes as well. I think the stock rear rotors look terrible behind 19" wheels. I'm considering the Baer rotors but I'm curious about the brake pads. Within the last 1500 miles or so I changed all the pads to GM ceramic pads and I'd hate to have to throw that money out because I need new pads with new rotors.
Can I rough up the pads with sandpaper???
Thanks.
Old Jun 22, 2011 | 04:45 PM
dougbfresh's Avatar
dougbfresh
Shouldn't have to do anything.
Old Jun 22, 2011 | 05:35 PM
bighank's Avatar
bighank
Default Good to go
Old Jun 22, 2011 | 06:52 PM
NatB's Avatar
NatB
Thanks.
If were me- I'd go ahead and sand the pads a little before reinstall with new rotors, makes sense to do so even with only 1,500 miles.
Old Jun 22, 2011 | 07:29 PM
spdislife's Avatar
spdislife
Old Jun 22, 2011 | 07:42 PM
bumble-z's Avatar
bumble-z
w/dougfresh
I went w/ the Baer 14", 2+2's.
I kept my ceramics. No problem, except if you plan on doing alot of hard breaking. If so, go w/different pad, but keep the ceramics for when your not planning on doing your road racing or whatever.
Good luck
Old Jun 22, 2011 | 08:39 PM
ricknyc23's Avatar
ricknyc23
Originally Posted by spdislife
Old Jun 22, 2011 | 09:57 PM
NatB's Avatar
NatB
I'm outvoted
Old Jun 23, 2011 | 11:10 AM
dbaker's Avatar
dbaker
IMO....I would go ahead and get new pads.The Hawk HPS work well with my TPS slot's....and while you're at it,upgrade the lines to Goodridge SS lines and add Speedbleeders.
You'll be glad you did.
\db2
carolina
Old Jun 23, 2011 | 04:54 PM
MStrahan's Avatar
MStrahan
Thanks for the advise guys. Speed bleeders are certainly on the list of things to install along with SS lines.
Old Jun 23, 2011 | 05:47 PM
SaberD's Avatar
SaberD
depends on the condition of the pads. if they have grooves in them, sand em unless you want grooves in your new rotors.
To changing rotors...what to do w/ current pads
