Backfire after longtube header install.
Old Jun 22, 2011 | 09:34 PM
96mogt's Avatar
96mogt
Default Backfire after longtube header install.
Hey guys I just did a good amount of upgrades to the car. MTI cam, UD pulley, Borla stinger exhaust and a set of tpis longtube headers. I just installed the headers today and the car backfires when I go in reverse for some reason. It doesn't have cats anymore and the air tubes were deleted as well. Do you all plug the hose that leads to the airfilter? I traced it and it went from my air tubes to my vararram intake. Is it because its too lean? Any help would be great. I need a tuner in SC really bad!!! Thanks Jay.
Old Jun 22, 2011 | 09:55 PM
BigthunderNos's Avatar
BigthunderNos
If it dose not do it in drive or driving normal,when you back up it has some sort of retard so you can not go fast or a burnout in R I think unless you hit the traction control button
Old Jun 22, 2011 | 09:59 PM
BigthunderNos
The air tube hose gos to your air pump and then your air cleaner and it will not do anything it is air pump you can take all of it off but unless you unplug the pump under your left front headlight I would not do anything with it
Old Jun 22, 2011 | 10:10 PM
96mogt's Avatar
96mogt
UPDATE: found a cracked plug. heading to get a new set right now! Jay
Old Jun 22, 2011 | 11:43 PM
bumble-z's Avatar
bumble-z
Just read your post & that is the first thing (cracked porcelain on
the plug) that came to my mind.
Glad you were able to find the problem.
Old Jun 23, 2011 | 10:14 AM
96mogt's Avatar
96mogt
Replaced the plugs last night and she runs like a champ!!Boy these Borla Stingers are really loud without cats!! Jay
Old Jun 23, 2011 | 01:13 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Originally Posted by 96mogt
UPDATE: found and cracked plug. heading to get a new set right now! Jay
Same thing happened to me. Glad you figured it out
Old Jun 23, 2011 | 01:24 PM
csexton's Avatar
csexton
Glad you found it!
Chuck
To Backfire after longtube header install.
