do you have to program new door control module?
Old Jun 24, 2011 | 07:59 AM
donaldmiller_69's Avatar
donaldmiller_69
Default do you have to program new door control module?
Just ordered a door control module for passenger side on a 98. Now when I install it does it have to be programmed to work? Or should it work on its own?
Old Jun 24, 2011 | 10:06 AM
airbrush1's Avatar
airbrush1
wondering the same thing! timely post!
Old Jun 24, 2011 | 10:21 AM
CSM87's Avatar
CSM87
Nope,
Plug and Play.
Old Jul 14, 2011 | 06:24 AM
dawiz's Avatar
dawiz
Originally Posted by CSM87
Nope,
Plug and Play.
has this been confirmed?
Old Jul 14, 2011 | 06:25 AM
donaldmiller_69
It's true. Worked for me. Didn't have to program nothin
Old Jul 14, 2011 | 06:28 AM
dawiz's Avatar
dawiz
this is whty i ask...
DCM Programming/RPO ConfigurationThe service DCM must be programmed by using a scan tool (hardtop only). The DCM stores information regarding the vehicle option content. If the DCM is not properly configured with the correct option content, the DCM will set default values for some systems which could cause system malfunctions. When a DCM is replaced on hardtop vehicles only, perform the following programming procedure:
DCM Programming (Hardtop Only)
Important:
Before proceeding with this programming procedure, check for proper communications between the DCM and the scan tool. If communications cannot be established, refer to the DCM Diagnostic System Check.
Maintain the battery voltage while the DCM is in the programming mode.
Using a Tech 2, select LDCM if the LH DCM was replaced, or RDCM if the RH DCM was replaced.
Select DCM Reprogram.
Follow the instructions on the remaining screens.
of course i have an frc (hard top)
Old Jul 14, 2011 | 10:13 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
From what I have gathered, it will work BUT,, it just may not work correctly and have issues.
So,, that said,,, if you see that its "not" working correctly,, just have any garage with a tech 2 program it for you. Its most likely NOT going to hurt the module.
Old Jul 14, 2011 | 11:20 AM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
very interesting...always thought it was plug and play, looking at the electronics. I suppose it makes sense considering the 'memory' feature...report back to us when you know for sure.
Old Jul 14, 2011 | 11:34 AM
byronhunter's Avatar
byronhunter
dawiz, please tell us where you found this information.--------------------------------------------------
Important:
Old Jul 14, 2011 | 11:37 AM
87SAM's Avatar
87SAM
The service manual does not mention reprograming when the module is replaced.
Old Jul 14, 2011 | 03:51 PM
airbrush1's Avatar
airbrush1
Just replaced mine on the Z06 3 days ago.... no programming needed at all!
Old Jul 14, 2011 | 08:37 PM
byronhunter
That is correct!
Old Jul 15, 2011 | 10:12 AM
87SAM's Avatar
87SAM
I did find the doc that dawiz was referring to. It’s a separate doc in the same section as the door module replacement. Why it’s not linked in the replacement procedure is
To do you have to program new door control module?
