Throwing codes: can someone decipher?
Apr 24, 2002 | 10:51 AM
58 SDM B1001H
AO-LDCM U1064H
BORFA U1096H
" " UI016H
A1 RDCM U1064H
I just did an ls-6 intake install last night, huge vacum leak someplace.....
Apr 24, 2002 | 10:57 AM
Re: Throwing codes: can someone decipher? (90 droptop)
Go to
http://www.stengel.net/diccodes.htm The explanations are short but, it should give you some idea of the problem. Good luck.
Apr 24, 2002 | 11:31 AM
St. Jude Donor '07-'12, '20
These are old history codes.
Bob
Apr 24, 2002 | 01:45 PM
Those are history codes. You shouldn't have anything to worry about unless they keep popping up as current. :)
Apr 24, 2002 | 06:50 PM
Re: Throwing codes: can someone decipher? (B. Stewart)
Thanks for the help!!!
Apr 24, 2002 | 06:56 PM
Vacuum leak is coming from passenger side rear of intake where the only vacuum line is connected to intake. :seeya
Apr 24, 2002 | 10:02 PM
Thaks for the help, I just reinstalled the intake, the small vac. hose had come off the back during the original install. PITA. Thanks Again!!
Apr 25, 2002 | 11:13 PM
The codes are also listed in the Tech section on the Forum. :cheers:
Apr 26, 2002 | 01:21 AM
Re: Throwing codes: can someone decipher? (16Again)
I have thrown code P1870 twice while racing. This number is not listed. Any ideas? Thanks
