Noise
Old Jun 26, 2011 | 09:59 AM
Vic'sVette's Avatar
Vic'sVette
Default Noise
Newby here. I just bought a 2001 coupe. 80k miles. She was wrecked on the right side 3 or 4 years ago but repaired by a good shop. She has a road noise that I did not notice when I test drove because dude had the top off(maybe because he didnt want me to hear the noise....) It appears to be coming from the rear. I really cannot tell if it is related to one side or the other. I initially thought it might be the tires because she needs new ones. But now I notice that it gets a little louder as I go around a left curve and quieter as I go around a right hand curve. More noticeable in town at speeds below 50mph or so and less at hiway speeds above 50 or so. I dont think its engine or tranny related because it does not fluctuate with the rpm's. It's progressive as related to speed. It's noticeably loud but tolerable. No engine codes exist. There is a 'service active handling' 'service abs' & 'service traction' message. I know its hard to armchair diagnose problems but just wanting input if anyone has suggestions.
Also looking for a good mechanic in northwest Arkansas that maybe works on the side that will be a little more reasonable than your local bow tie dealer. (I took her to one here local to have an ac belt and a front marker lamp installed and it cost me over $150.... I just didn't want to do it because I work a lot of hours and it was hot and I just did not want to do it at the time. boo hoo. I know....) I knew a guy that was a certified gm mechanic that did work on the side but we have moved. He is a few hours away.
Thanks in advance.
Old Jun 26, 2011 | 10:13 AM
Paul Wood's Avatar
Paul Wood
Welcome to the world of Corvette Forum and Corvette ownership! The forum here is filled with people with tons of knowledge and experience. Your issues are quite common and if you will utilize the search function you will find a wealth of information that will give you direction. Read through what you can tolerate and ask questions. The more data you can provide in the way of codes and year, model, and any engine mods will speed up the process of finding your solutions. Good luck and happy motoring!
Old Jun 26, 2011 | 10:54 AM
Vic'sVette's Avatar
Vic'sVette
Thanks for the reply Mr. Paul. Did a little searching & sounds like noise is a common issue w/ C5's. The only thing that concerns me is that it's louder when I turn left & quieter when I turn right. Is this common??? Thanks again.
Old Jun 26, 2011 | 11:38 AM
lionelhutz's Avatar
lionelhutz
That sound changing when turning sounds like it could be a wheel bearing. My guess would be the left side but it's possible the right side bearing was damaged in the accident.
Peter
To Noise
