Maf and diffuser
Old Apr 24, 2002 | 01:34 PM
Michaeljh3's Avatar
Michaeljh3
Default Maf and diffuser
When installing a new intake, Vortex or Blackwing, is it worth it to replace the maf ends as well and yank out the diffuser on a stock 2000 6 speed?
[Modified by Michaeljh3, 5:34 PM 4/24/2002]
Old Apr 24, 2002 | 04:52 PM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
Default Re: Maf and diffuser (Michaeljh3)
You will get a few more ponies from the ported maf ends and screen removal... IMHO it is a worth-while mod :yesnod:
Old Apr 24, 2002 | 06:02 PM
Michaeljh3's Avatar
Michaeljh3
Default Re: Maf and diffuser (Smoke-N-Shot)
Ok...sounds good.
As to porting the maf: Is that something that is done to the original maf, or something else that I need to buy?
Old Apr 24, 2002 | 06:31 PM
yellowy2kc5's Avatar
yellowy2kc5
I'd just remove the screen and save the trouble of porting, at least on a stock head/cam car. '98 TA I used to have picked up 8rwhp from a ported MAF, my '00 vette picked up 6 rwhp from just removing the screen. 2 hp diff isn't anything. A ported MAF is more likely to mess with air/fuel ratios as well since you are changing the volume of the MAF, though this may be a benefit if you are running rich.
To Maf and diffuser
