Ebcm
Old Jun 27, 2011 | 11:32 PM
jims01vette's Avatar
jims01vette
Default Ebcm
Ok, need some help from some of you fine fellows. Sent ebcm in to be repaired and was told the micro processor was bad, so i bought a rebuilt one. Put the new one in and recieved tcs codes 1287-1288 steering rate malfunction. I have checked fuses and grounds, all looks good. When test driving it i stepped on the brake a little as i was turning and felt a vibration come from the right front wheel and in the brake pedal? Also is there a steering sensor? If so where is it located. Thanks, jim
Old Jun 27, 2011 | 11:56 PM
jcgunn's Avatar
jcgunn
1288 code is the SPS (steering position sensor)
Old Jun 28, 2011 | 12:26 AM
jims01vette
Thanks jcgunn, can you tell me where that sensor is located.
Old Jun 28, 2011 | 11:58 AM
coia96vette's Avatar
coia96vette
sensor is on the steering column inside by the firewall. Yellow and geen disc shaped. I had those same two codes and replaced the swps and all is fine now. Got it from Gene at GMpartshouse for about 63.00 plus shipping. About a three hour job to replace.
Old Jun 28, 2011 | 12:11 PM
GoBallsDeep!'s Avatar
GoBallsDeep!
forums.corvetteforum.com/c5-tech/1671631-any-tips-on-replacing-the-steering-wheel-position-sensor.html
To Ebcm
