Service Active Handeling
Old Jun 28, 2011 | 04:12 PM
Toxiclemonade's Avatar
Toxiclemonade
Default Service Active Handeling
Recently the car has been warning me to "service active handeling" as well as "active handeling warming up" and I pulled these codes: c1286, c1287, and c1288. Could the sensor be unplugged? The suspension has 130k on it and I want to replace it with the c6 z06 set up anyways so is now the time to do it?
Old Jun 28, 2011 | 05:31 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I'm thinking your steering position sensor is having issues. Clear the codes and see what comes back and under what circumstances.
Old Jun 28, 2011 | 06:15 PM
GoBallsDeep!'s Avatar
GoBallsDeep!
^+1
Honestly, I've seen this post a lot as of late...Here is a good thread. This is the 3rd time I've pasted this link today
http://forums.corvetteforum.com/c5-t...on-sensor.html
Old Jun 28, 2011 | 10:24 PM
Toxiclemonade
Originally Posted by GoBallsDeep!
^+1
Hey, thanks for the link but it doesn't work. -Ryan
Old Jun 29, 2011 | 08:54 AM
GoBallsDeep!
^Evidently, I am having a problem posting links..copy and paste into browser...
forums.corvetteforum.com/c5-tech/1671631-any-tips-on-replacing-the-steering-wheel-position-sensor.html
Old Jun 29, 2011 | 10:35 PM
Toxiclemonade
what if i got rid of the entire magnetic ride system by replacing it with the c6 z06 shocks and simulators? Would I need this steering sensor? I want to get rid of the set up anyways and its around 200 for the sensor and 250 or so for 4 shocks so it would make sense to get the shocks and the simulators instead of replacing the steering sensor.
Any input would be appreciated. Thanks. -Ryan
Old Jun 29, 2011 | 11:50 PM
Bill Dearborn's Avatar
Bill Dearborn
Active Handling doesn't have anything to do with the suspension. Two different systems. AH is part of the ABS system. AH uses the steering sensor to tell where you are pointing the car and then it uses the lateral G sensor and the yaw sensor to tell whether the car is yawing too quickly (oversteer) or not quick enough (understeer). If the car is oversteering the system will apply the outside front brake to decrease the yaw and if it is understeering it will apply the inside rear brake to increase yaw. The magnetic ride system just adjusts the shock absorbers and doesn't use the steering sensor.
You can go to a lot of expense getting rid of your shocks which are probably still good and still not correct the problem or you can replace the steering sensor which is a lot cheaper and fix the problem.
Bill
Old Jun 30, 2011 | 11:58 AM
Toxiclemonade
Bill
Thank you for the info Bill, I appreciate it. Guess I'll replace the steering sensor. -Ryan
Old Jun 30, 2011 | 12:26 PM
dgrant3830's Avatar
dgrant3830
FYI, Do Not allow the steering wheel to move after or while you are pulling the sensor out.
Old Jun 30, 2011 | 03:24 PM
Toxiclemonade
Don't you have to pull the entire steering column out of the car, steering wheel and all?
Old Jun 30, 2011 | 04:33 PM
dgrant3830's Avatar
dgrant3830
Last I saw, the sensor is at the base of the steering column on the inside. You don't want the column to spin on you when you disconnect it. I had the dealer do mine long ago so I wouldn't chance setting off the airbag but I'm thinking you only need to pull it up enough to pull the sensor off, stick a new one on there and lower it back in place. It may not be as easy as that sounds and truly I don't know as I didn't do it myself.
Old Jun 30, 2011 | 10:07 PM
Toxiclemonade
Hmmm, I've pulled the car aprt twice so I think I can tackle this. I'll look at the service manual and the link that was posted and see what comes of it. Thanks again for the advice. What did the dealership charge you by chance if you don't mind me asking? thanks. -Ryan
Old Jul 1, 2011 | 07:35 AM
dgrant3830's Avatar
dgrant3830
This was years ago, they charged me $175 for labor.
To Service Active Handeling
