DTC C1281 and C1288.
Old Jun 28, 2011 | 08:11 PM
memphis_vette's Avatar
memphis_vette
Default DTC C1281 and C1288.
I took my steering shaft off the rack and accidentally spun the shaft. Have no clue how many times, but now I have these codes. What do I have to do to get the steering wheel position sensor happy?
Old Jun 29, 2011 | 08:55 AM
memphis_vette
Bump. Anyone know or is this a dealership thing?
Old Jun 29, 2011 | 12:04 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Bill Curlee or Lucky131969 will most likely have the answer...possible 8VETTE7 too. What you need is the alignment procedure from the manual.
Old Jun 30, 2011 | 12:47 AM
memphis_vette
^^^ I do have a manual if you can point me in the right direction through that?...ill ask BC as well. thank you
Old Jun 30, 2011 | 10:21 PM
memphis_vette
Any input?
Old Jul 7, 2011 | 11:14 PM
Kurt Sanger's Avatar
Kurt Sanger
6th Gear
You will need to search for how to reset the steering wheel relative to the air bag. The air bag has a thin wire to it, and it only allows the wheel to turn so far before it will break. There is a procedure to align the wheel to the air bag. Hopefully you haven't killed the air bag.
I was able to get my sensor working by removing it from the column, then turning it past its normal limits while reading the pot using an ohm meter. You need a multi-meter with the ability to turn off auto ranging. Otherwise its hard to tell if the meter is hunting between ranges or the pot is intermittent.
There is a small hole in the bottom of the sensor for a pin to lock it in the neutral, center, position. I just set it to the middle of its range using the ohm meter. Then slid it back onto the column so that the tab locked into the slot on the column. If its a multi-turn pot you can't just put a pin in and turn the pot until the pin locks it up. You will need a multi-meter with a resistance, ohm, setting. Different years have different pin-outs. I believe there are at least two different types.
Good luck.
Old Jul 7, 2011 | 11:27 PM
Bill Dearborn's Avatar
Bill Dearborn
Hopefully you haven't hurt the air bag clock spring by turning the wheel to far. Another way to check the sensor position is to use a voltmeter to read the voltage across pins 5 and 6 of the sensor. You will need to jury rig some wires into the connector so you can hook up the meter while the connector is connected. As you turn the wheel with the ignition on the voltage will increase or decrease. If it increases turn the wheel the other way. If it decreases keep turning until it starts to go back up. The wheel will be centered once the voltage is at its lowest level.
Bill
Old Aug 30, 2011 | 11:14 PM
memphis_vette
the clock spring is broken, is this a DIY or dealership fix?
Old Aug 30, 2011 | 11:15 PM
memphis_vette
is the car drive able to the dealership if i have them fix it?
Old Aug 30, 2011 | 11:18 PM
shadowman1's Avatar
shadowman1
The clock spring isn't that hard to change but you will have to pull the air bag out and the steering wheel off. Do you have a service manual?
Dave
Old Aug 30, 2011 | 11:51 PM
memphis_vette
i do have a service manual...i work at a dealership so i will get pricing 2mro to see if i will get robbed or not. i would much prefer to do it myself tho
Old Aug 31, 2011 | 12:04 AM
shadowman1's Avatar
shadowman1
You will need a steering wheel puller and I dont know if the air bag takes a special removal tool or not. My C4 just had 2 torx screws to remove the air bag but I think the C5's take a flat bar tool to unhook the air bag. Check your service manual. The tool is not very much to buy if you need it.
Dave
Old Aug 31, 2011 | 12:08 AM
memphis_vette
ok thank you for the help, i think i will just have the dealership do it...ill look more into it
To DTC C1281 and C1288.
