ls1 smoking
Old Jun 28, 2011 | 09:48 PM
hatewhatownsyou's Avatar
hatewhatownsyou
Default ls1 smoking
2001 40k, ported heads, cam, valve springs, long tubes, hi-flow cats.
its a 2001 which i know is known for having bad oil rings. the car has always consumed some oil(cant tell you how much exactly, never really kept track) but recently it started randomly smoking during idle/driving and i will leave a cloud when i go WOT.
it started last month when i changed the oil and went autocrossing. first off i used the wrong oil(10w/30) and second i put in an extra quart, ever since its been doing this.
today i pulled the throttle body, the intake is coated in oil and maybe a teaspoon of oil sitting in the bottom. so i pulled the intake and currently have it standing up to drain any oil(what can i spray inside to clean it?). i put on new valve stem seals last winter when i did my valve springs.
would installing a catch can be a good start? im hoping this is just suddenly caused from me overfilling the oil and the shity pcv design.
i have not done a leakdown or compression test, i dont have that equipment.
Old Jun 29, 2011 | 11:27 AM
hatewhatownsyou
Bump
Old Jun 29, 2011 | 11:39 AM
cdkcorvette7's Avatar
cdkcorvette7
Free bump... Someone who knows better than me will jump in here but I don't think a catch can is going to even come close to fixing your problem... I also think a compression test is in order, a lot of auto parts stores will rent stuff like that.
Old Jul 6, 2011 | 09:33 PM
hatewhatownsyou
seriously? bump.....
i deleted the pcv system and added a breather. maybe this weekend i will have time to do a compression test. local autozone should have one.
Old Jul 6, 2011 | 09:54 PM
Jnape's Avatar
Jnape
Do a leak down test. It will be more accurate as to your crankcase pressure issue. If you have vented the engine without the pcv and you are not F/I, your rings are probably the issue.
Old Jul 6, 2011 | 10:48 PM
mchicia1's Avatar
mchicia1
Did you put sealant on your intake rocker bolts?
Old Jul 7, 2011 | 10:52 AM
wagner262's Avatar
wagner262
How many quarts of oil did you put in?
Old Jul 8, 2011 | 12:10 AM
Jnape's Avatar
Jnape
He stated 1 qt over full. Totally recommended for auto-x or road race if you are pulling sustained G's.
Old Jul 8, 2011 | 05:27 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
You can also use 10W-30 if the ambient temperature is high enough, read your owner's manual. Eliminating the PCV system was a mistake, I would re-install it if I were you. Filling the oil level past the full mark for autocross is unecessary.
I suggest you read GM's TSB on the ring flutter issue if you have not done so; it will help you understand what is actually going on rather than just assuming the rings are bad. There may be some driving related things you can do to significantly reduce and or eliminate the excess oil consumption, these are discussed in the TSB. In your case your results may be less than satisfactory since you appear to have done some modifications that are probably contributing to the problem.
To ls1 smoking
