traction light on
Old Jun 29, 2011 | 11:10 AM
kennyi's Avatar
kennyi
Cruising
Default traction light on
traction controll light on
hey guys my traction light is on and it wont go off .. week ago it would come on while i hit 10 mph and would stay on until i truned the car off and on then it would be fine.... well now it just stays on all the time button wont work and no codes .... i didnt have this problem untill i cleaned all my grounds wonder wich ground works the traction controll... plus i always had the code wich means tire pressure senser is not working. had that ever scnce i changed my wheels .. about a year ago . i no how to clear it but never did yet plus it never made my traction light come on /
thanks
Old Jun 29, 2011 | 11:42 AM
cdkcorvette7's Avatar
cdkcorvette7
Traction control light on and the button is inoperative... Are you sure you don't have any codes? How are you reading them?
Old Jun 29, 2011 | 11:58 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
For that light to be on, there has to be a code(s) present unless you've manually turned it off at the button which you say isn't working. Have you checked to see if the connector is plugged into it?
Old Jun 29, 2011 | 12:53 PM
Bluefire's Avatar
Bluefire
thanks
Have you re-checked the quality of your work?
Old Jul 5, 2011 | 12:38 AM
kennyi's Avatar
kennyi
Cruising
i have acode 1277 wich i looked up and it said something about tourqe senser .. would thi be ground issues .
Old Jul 5, 2011 | 07:58 AM
dgrant3830's Avatar
dgrant3830
C1277 Requested Torque Signal CKT Malfunction
I don't know anything about this code but hopefully someone else will. Try clearing it now and see if it comes back.
To traction light on
