Sunvisers
Old Jul 1, 2011 | 03:15 PM
memmer's Avatar
memmer
Default Sunvisers
Just recieved my new sunvisers for my 2001 C5 Vert.No instructions on how to R&R can someone help me?I will very much appreciate it.Thank you.
Fred
Old Jul 1, 2011 | 03:44 PM
DavyC's Avatar
DavyC
Removal Procedure
- Tilt the sunshade down toward the windshield.
- Insert a flat head screwdriver blade into the slot in the sunshade inner bezel.
- Using the screwdriver against the elbow of the sunshade arm for leverage pull down on the sunshade arm while rotating the sunshade outboard until the sunshade stops. (the first tab disengages).
- Push up on the sunshade and continue rotating the sunshade outboard until the sunshade with the inner bezel disengages from the mounting bezel.
- Disconnect the electrical connector.
- Remove the sunshade.
- Disassemble as necessary.
- If removing the mounting bezel, pull the bezel from the garnish molding with your fingers.
- If replacing the inner bezel, remove the bezel from the sunshade shaft and press the new bezel onto the shaft.
Installation Procedure
- Route the harness through the mounting bezel.
- Insert the mounting bezel into the garnish molding engaging the snap fingers.
- Connect the harness to the sunshade electrical connector.
- Push the connector up through the bezel and through the hole in the garnish molding.
- Position the sunshade approximately midway between the windshield and the side of the vehicle.
- Insert the rod with inner bezel firmly attached fully into the mounting bezel.
- Rotate the sunshade toward the centerline of the vehicle until the sunshade locks in place.
There are some pictures from the manual I couldn't get in here. I used these when modifying my visor with the Homelink garage door opener.
Dave
Old Jul 1, 2011 | 05:52 PM
memmer's Avatar
memmer
thank you Dave. Pictures would be nice
Old Jul 1, 2011 | 06:10 PM
JJ 86's Avatar
JJ 86
Old Jul 2, 2011 | 01:07 PM
DavyC's Avatar
DavyC
Try this:
http://www.pdfhost.net/index.php?Act...d686edd1d1bee6
Dave
Old Jul 2, 2011 | 08:32 PM
bdog's Avatar
bdog
Fred
Just wondering... Where did you get them and how much did you pay??? I need to replace mine so bad! Thanks!
Old Jul 4, 2011 | 01:03 PM
memmer's Avatar
memmer
bdog PM sent about wipers
Old Jul 27, 2011 | 01:53 PM
Heavy Hauler's Avatar
Heavy Hauler
thanx for the info. my mobile headliner guy was unable to figure out how to remove them, so I knew the answer could be found right here. very simple very easy!
Old Dec 4, 2011 | 02:52 PM
Tractors4u's Avatar
Tractors4u
I just got my new/used visors installed. The previous owners didn't take very good care of this car and I've had to repair or replace lots of things so far. This is a great forum.
To Sunvisers
