Shift Knob
Old Jul 5, 2011 | 12:33 AM
torchredmadness's Avatar
torchredmadness
Default Shift ****
Simple question....to change the shifter **** on our '03 C-5 do I just grab the old one and twist it off lefty loosey righty tighty? We're new to the Corvette familly. Having fun so far.
Old Jul 5, 2011 | 01:08 AM
m6 c5's Avatar
m6 c5
It varies depending on whether it is auto or manual. If it is manual then you have to remove the shift pattern plastic piece by just prying it up being careful not to mar the shifter and then remove the locking key that is on the inside. Once that key is out you can then twist it off, oh and that key is often referred to as the demon key.
If it is an auto then there is a staple on the front of the **** that has to be removed before you can take it out, I believe that you twist that one off too but Im not too sure about that.
Old Jul 11, 2011 | 01:54 AM
torchredmadness
Thanks for replying to such a simple task. Your instructions were perfect. I swapped to a 2" 8 ball type shift ****. Very comfortable.
Old Jul 11, 2011 | 10:04 AM
m6 c5's Avatar
m6 c5
Glad you were able to get the key out, I still havent managed to get it out of mine so Im just going to swap out the entire shifter one of these days.
Old Jul 11, 2011 | 12:07 PM
SDPC's Avatar
0SDPC
Former Vendor
Unless you plan to buy a new boot, you'll still have to get the old **** off I've seen the key broken OFF before from people trying so hard to remove it
Old Jul 11, 2011 | 06:20 PM
m6 c5's Avatar
m6 c5
Yes I know, I am going to eventually get a new boot and **** as I already have a shifter that I have cut down.
To Shift Knob
