Damp A/C smell
First, spray Lysol directly into the vent area outside your car where the windshield wiper is. This will help to kill the bacteria that is causing this smell. I was also told to make sure to run the a/c using outside air first, for the first 2 miles. Then, you can revert to the inside circulation which provides a stronger rush of air.
http://autorepair.about.com/cs/heati.../aa071601a.htm
From The GM manual
Odors may be emitted from the air conditioning system primarily at start up in hot, humid climates. The following conditions may cause the odor:
- Debris is present in the HVAC module.
- Microbial growth on the evaporator core
Deodorize the evaporator core using Deodorizing Aerosol Kit.
Perform the following steps in order to deodorize the A/C system:
- Ensure that the plenum that draws outside air into the HVAC module is clear of debris.
- Disable the A/C compressor clutch operation by disconnecting the clutch coil electrical connector.
- Dry the evaporator core by performing the following steps:
- Start the engine.
- Select the maximum temperature setting.
- Select the recirculation mode.
- Run the blower motor on high for 10 minutes.
- Locate an area in the air conditioning duct between the blower motor and the evaporator core downstream of the blower motor.
- Drill a 3.175 mm (0.125 in) hole where the hole will not interfere with or damage the following components:
- The blower motor
- The evaporator core
- Any other operating part the of system
- Wear safety goggles and latex gloves in order to perform the following actions:
- Select the maximum blower speed.
- Insert the deodorizer extension tube into the hole to the mark on the extension tube.
- Use short spray bursts and vary the direction of spray for a 2-3 minute period of time.
- Shut the engine OFF. Allow the vehicle to sit for 3-5 minutes.
- Seal the 3.175 mm (0.125 in) hole with body sealer or RTV gasket compound.
- Start the engine.
- Operate the blower motor on high for 15-20 minutes to dry.
- Reconnect the A/C compressor clutch coil electrical connector.
- Verify proper clutch operation.
I thread I found doing a search, hope it helps
