Ca emissions
Old Jul 7, 2011 | 10:41 AM
wagner262's Avatar
wagner262
Default Ca emissions
i just bought used cats from a z06 with low miles about 40k or so. if i have them welded on to my obx long tube headers will it pass emission? not worried about visual.
Old Jul 7, 2011 | 02:57 PM
tiojames's Avatar
tiojames
Some of the smog stations don't use the feeler in the exhaust pipe, but use the computer read out on the car. I would give Andy at A&A (forum vendor in Oxnard, Ca.) an e-mail and see what he says.
Old Jul 7, 2011 | 03:26 PM
BitViper's Avatar
BitViper
Emissions's.. only the niffer will tell.. BUTyou will fail the visual with headers
Old Jul 7, 2011 | 03:30 PM
69SSC5's Avatar
69SSC5
as long as you dont have a bigger cam than what came stock in your z06, your cats are brand new (and nice and warmend up when the sniffer goes in), new air filter and fresh oil you should be A OK
Old Jul 7, 2011 | 03:32 PM
69SSC5's Avatar
69SSC5
i just caught that you bought used cats not new cats,,, hmmm..... as long as the cats are good you should still be ok... just make sure the engine and exhaust are nice and warm
Old Jul 7, 2011 | 10:53 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
GM OEM cats are really efficient. If you have them properly warm and your tune is in good shape,, you will be GOLDEN! Do you know what your Long Term Fuel Trims are reading at idle and closed loop steady state cruise???
BC
Old Jul 8, 2011 | 01:47 AM
wagner262's Avatar
wagner262
i have an frc and they are from an z06 with around 40k i just changed my oil with in 2k.. it might be time for a tune up eventually but it doesnt run that bad.
i dont know anything about smog but when it was idle the number was in the double digits i dont remember. but when he reved it to 2k rpm it was around 300 was the number. not sure the measurement is. the guy i went too didnt even know i had headers and he even took off my engine plastics. he still was fine with it.
Old Jul 8, 2011 | 05:40 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
I doubt you will be able to weld them on and keep the OEM cats within the floorpan recess area and maintain the necessary ground clearance. It's only a matter of time before you come across a technician that knows long tube headers are not CARB approved.
Old Jul 8, 2011 | 08:17 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I recently bought some used cats from someone here to replace my super high mileage ones on my '99. I stopped at more than one muffler shop only to be told its against federal law to put on "used" cats, so they won't do the job.
Old Jul 8, 2011 | 04:46 PM
wagner262's Avatar
wagner262
im going to a weld shop not a muffler shop. i always legally smogged my car and have never once had the shop put my car on a lift. my car is to low just to look under the car and see the cats. where im from a lot of the smog shops are pretty chill. they just want to see it pass emissions
To Ca emissions
