LS1 Thermostat Spring Loaded?
Old Jul 10, 2011 | 12:43 AM
bheston's Avatar
bheston
Default LS1 Thermostat Spring Loaded?
So I put my new water pump on and (02 Vert). The GM guy gave me the new LS1 pump and thermostat housing. When I put the thermostat in, it bottoms out inside the housing and has some spring tension from the thermostat spring.
Is that normal?
Old Jul 10, 2011 | 02:24 AM
BRISLS1's Avatar
BRISLS1
St. Jude Donor '11, '14,’19
I did a Mr Gasket thermo for 160. It had the bottoming out. Works like a champ. Loving the cool numbers. Hope that helps to compare. Kind of spooked me at first too.
Old Jul 10, 2011 | 09:22 AM
bheston's Avatar
bheston
Yea. Seems strange for the bottom of the stat to bottom out inside the water pump. Should I fill 'er with antifreeze and see where the fan turns on?
Old Jul 10, 2011 | 11:39 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
the fans will turn on at the same time before the swap. they are programmed in the pcm. you need to have the fans changed to lower the temp
Old Jul 11, 2011 | 10:25 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I've run into this exact thing as well. GM parts, that is supposedly the replacement for it. The part number exchanges over to the LS2/3's as well. I went ahead and put it in and will see what happens but so far in the summer heat, its been fine. Not sure what will happen come the winter but we'll see.
To LS1 Thermostat Spring Loaded?
