C5 LS1 overheating?1
Old Jul 10, 2011 | 10:33 PM
Bumble Boogie's Avatar
Bumble Boogie
From: River City USA, East of the Mississippi Peoples Republic of Illinois
Default C5 LS1 overheating?1
I'm on a road trip with my C5. Encountered 95 degree F temps and engine temps rising to 226F. Temp held then dropped. Headed for South Texas and air temps of 112F. Should I be concerned about engine temps that high or is this not out of the norn? A bit concerned, or is my concern for naught?
Old Jul 10, 2011 | 11:34 PM
jcgunn's Avatar
jcgunn
You should see about 198 going down the road, somewhere higher in traffic and up to 220-228 in the Wendy's drive thru. If you see more than this, remove the crud and debris from the radiator.
Old Jul 10, 2011 | 11:36 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
Just make sure nothing is caught up in the airdam. In south texas a T stat and a quick change in fans temps makes for a cooler running texas car
Old Jul 10, 2011 | 11:47 PM
02koolC5's Avatar
02koolC5
also running ac should help ya cool engine temp
Old Jul 10, 2011 | 11:51 PM
Bumble Boogie
How do you quick change fan temps?
Old Jul 11, 2011 | 06:07 AM
baxsom's Avatar
baxsom
you have to reprogram the pcm to make the fans come on quicker.
Old Jul 11, 2011 | 06:59 AM
AU N EGL's Avatar
AU N EGL
Clean out the radiator from all the dirt and grass will help dramatically reduce coolant temp
Old Jul 11, 2011 | 07:16 AM
Bumble Boogie
Does that have to be done at dealer or can I do it?
Old Jul 11, 2011 | 12:08 PM
Chicago1's Avatar
Chicago1
Actually 226 is not "OVERHEATING" I'm surprised noone has said this but that is the way the car is supposed to be from the factory....
"The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
This is right from the tech manual.
Old Jul 11, 2011 | 02:20 PM
dougbfresh's Avatar
dougbfresh
There are always DOZENS of these posts this time of year-
Old Jul 11, 2011 | 05:28 PM
mchicia1's Avatar
mchicia1
Absolutely normal...see Chicagos post.
Old Jul 11, 2011 | 10:07 PM
Bumble Boogie
Default over heating
Thanks a bunch guys. Had the fans checked at Chevrolet in Republic, MO. All checked out fine. I'm happy and headin for San Anton in the morn with confidence. Thanks a bunch again guys.
Old Jul 11, 2011 | 10:56 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
If you want the fan temps changed and a T stat installed we (Lethal Performance) are in San Antonio and can help you out if you want the car to run cooler. I should have stated earlier that your temp is normal to OEM standards.
Old Jul 11, 2011 | 11:57 PM
Bumble Boogie
Just might look you guys up when I get get there. Thanks.
These forum members are super!
Old Jul 12, 2011 | 07:01 AM
JMBLOWNWS6's Avatar
JMBLOWNWS6
We are a sponsor. So no worries.
www.lethalperformancesatx.com
Ill be there the next 3 days finishing up my car.
To C5 LS1 overheating?1
