A/C help
Old Jul 12, 2011 | 01:30 PM
johnnyzvette's Avatar
johnnyzvette
Default A/C help
I'm having some issues with my a/c on my 98. I have the electronic dual climate control on my car and when i turn on the a/c, the passenger side blows cold very quickly while the driver side is warm and after about 10-15 minutes it will start to blow colder. Has anyone ever had this problem? What could be the problem?
Old Jul 12, 2011 | 01:59 PM
dmarkshark's Avatar
dmarkshark
Probably low on freon.
Old Jul 12, 2011 | 06:10 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
READ AND POST your DTCs
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
You can read the DTCs while the engine is running. If you turn the engine OFF and then back ON, that can clear some DTCs that may be important with identifying a problem. One example is a Misfire DTC (p-0300) If the engine is shut down, the DTC will clear.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Jul 13, 2011 | 10:02 AM
rebelheart's Avatar
rebelheart
Old Jul 14, 2011 | 07:12 AM
johnnyzvette
I will check my codes. How can i tell if i'm low on freon? I'm assuming i would have to buy a set of gauges and learn how to use them.
Old Jul 14, 2011 | 08:09 AM
dmarkshark's Avatar
dmarkshark
If you want to do it yourself, yes on the gauges. IF not, take it to an AC place. You can also buy a can of freon with a gauge on it, but thats really the lesser option on the three.
Old Jul 14, 2011 | 10:00 AM
Cratecruncher's Avatar
Cratecruncher
If this is a low refrigerant issue how does the passenger side vent get cold so quickly?..Wouldn't the passenger and driver sides take an equal time to start to cool down and even then be cool but not cold.
Old Jul 14, 2011 | 10:59 AM
johnnyzvette
That's exactly what i was thinking. Could it have something to do with the vents not opening correctly?
Old Jul 14, 2011 | 12:08 PM
dmarkshark's Avatar
dmarkshark
Could, but you should have some codes. When the AC cools, it enters and starts on the passenger side (from my understanding) and then the drivers side. Thus, it will cool the passenger side first and then the dirvers side. So, usually when it gets cold on the passenger and not the drivers, or the drivers side is less cool, its usually low on freon. This is a pretty common issue. Of course, the best way to really know is to 1) check for codes on the DiC and 2) put some gauges on it (or someone else).
Old Jul 14, 2011 | 12:21 PM
jrose7004's Avatar
jrose7004
My 98 was like that but I haven't had any issues with my 04.
Old Jul 14, 2011 | 12:23 PM
johnnyzvette
Ok, will do! Thanks for the help dmarkshark.
Old Jul 14, 2011 | 05:10 PM
johnnyzvette
Got it fixed! To all who said i was low on freon, you were right on! I didn't have any codes stored so i picked up a can of freon and added it, now all vents blow out ice cold air! Thanks guys for all the help! I love this forum!
Old Jul 15, 2011 | 10:44 AM
rebelheart's Avatar
rebelheart
To A/C help
