~ Belts, Balancer, Pulleys, ETC...~
I've done some research here, but wanna nail it down.
1. A few months ago, I began to hear a sqealing noise under the hood. I didn't think much of it, car had been running fine since then.
2. Every once in a while I get, "Recharge System Check". I changed to a new battery. I still get that message, but rarely now.
3. Last week I heard a really bad griniding noise in the front diver side wheel, like the bad bakes... But I knew that's not it, cuz I had changed the brakes last year. After a few miles on the freeway, the noise went away. I thought something might have gotten stuck in there, and got cleared up.
4. Last night noticed my steering wouldn't work. Looked under the hood, the belt had jumped off the Pulleys. The belt is still not broken, and doesn't seem really worn out either.....
So, what's the reason it jumped off? Are all these things related somehow....???
I'm more concerned about the #4 problem, at hand. Should I just buy a new belt and put it in there? Or do I need to change a pulley, or something? Sticking a belt in there doesn't seem so hard, however, loosening the pulleys and then getting it to the right tension seems quite awkward. I don't want to go out and buy every single pulley, etc.... Just want to do the needed, for now.Thanks in advance...
A new balancer will cost you about 800 dollars installed ( 5 hours shop time labor )..that's parts and labor ... including two new belts and a front seal, which you will need. If the balancer goes completely, you will loose your engine..
Bill aka ET
1) is the bolt backing out.
2) the HB is a three piece unit, 1)the internal balancer connected to the 2)outer pulley and the 3)elastomer center, when the elastomer becomes degraded through heat, it will cause the outer pulleys to wobble... when the elastomer starts to smell like burning rubber and you are seeing little pieces of rubber, the HB is about to let go. In either case you need to remove the steering rack and get to the bolt.. at this point, you want to change the HB anyway. You can use a steel underdrive pulley and get 10 extra ponies. I would not use a New 3 piece GM balancer. IN either case you will need a new crank bolt. While you are in there you want to replace the crank seal.
Bill aka ET
BTW search is your friend.. see some of the hundred post on this subject under my name.
Bill aka ET
Anytime we're talking gains in HP, I like that..
1.Which pulley am I replacing with the new under-drive pulley?
2. Now, What's the bad news? Do I really have to change the HB? How much does it run for anyways...
3. And should I change both, or one belt?
4. Any other pulleys need changing?
Thanks.... Love the forum....
So I pulled the codes, but don't really understand them. Here's what I got -
10PCM - P1637 H
28-TCS NO CODES
40BCM NO CODES
58-SDM B1001 H
58-SDM U1016 H
60-IPC NO CODES
A0-LDCM B2282 H
A0-LDCM B2284 H
A0-LDCA U1064 H
A1-RDCM 82283 H
A1-RDCM 82285 H
A1-RDCM U1064 H
BO-RFA U1096 H
BO-RFA U1064 H
BO-RFA U1016 H
I have the codes worksheet with all codes, showing the problems, but these codes not listed there
. Please help...
