Where is the ground for the alt.
Old Aug 5, 2011 | 10:18 AM
JJ 86's Avatar
JJ 86
Default Where is the ground for the alt.
Having low voltage issues with my alt. Recently had the alt powder coated and now have a low voltage problem. The mounting ears do not have any power coating on them. Any ideas?
Old Aug 5, 2011 | 10:37 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Was the unit taken apart before the power coat?
Old Aug 5, 2011 | 10:52 AM
cdkcorvette7's Avatar
cdkcorvette7
Search is your friend: http://forums.corvetteforum.com/1557187612-post5.html
Also... is this a duplicate thread? Seems like I read about something like this after an alternator powdercoating earlier today?
Old Aug 5, 2011 | 11:17 AM
lucky131969's Avatar
lucky131969
Ahhh...yeah.....I don't think he believes me...
http://forums.corvetteforum.com/c5-t...lp-please.html
Old Aug 5, 2011 | 11:26 AM
JJ 86's Avatar
JJ 86
I've done a search on multiple forums. The problem is that i find others with the same problem but they didn't specify what they did to fix the problem. Lucky131969... its not that i don't believe you.. I wanted to get other opinions as well.
Old Aug 5, 2011 | 11:32 AM
lucky131969
No problem. I'm not very good with this electrical stuff.
Old Aug 5, 2011 | 11:54 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
At only 11 volts output, as stated on the other thread, it sounds like you have more than a grounding issue.
It's easy enough to check that the alternator case is properly grounded.
There should be no more than 0.5 Ohms resistance, when measured from the alternator case to the negative terminal on the battery.
Old Aug 5, 2011 | 12:16 PM
Eric D's Avatar
Eric D
He doesn't believe you! I mean come-on now. As many people as you have helped on this thread Lucky, it's about time you start lying!!
Old Aug 5, 2011 | 12:22 PM
JJ 86's Avatar
JJ 86
Ok so far I've check the external contact points (mounting ears). I get .2 ohms when i checked the resistance from the case to the battery. Does the .2 sound right?
Old Aug 5, 2011 | 02:15 PM
dougbfresh's Avatar
dougbfresh
Sounds like a diode in the regulator is bad.
Old Aug 5, 2011 | 04:34 PM
Eric D's Avatar
Eric D
How exactly does a diode sound? Anyone have a recording they could post?
Old Aug 5, 2011 | 04:36 PM
dougbfresh's Avatar
dougbfresh
POP!
Old Aug 5, 2011 | 05:48 PM
Quicksilver Vert 01
Like I said earlier, anything less than 0.5 ohms is good. 0.2 ohms is fine.
You alternator problem is caused by something internal, not an external grounding issue.
Old Aug 5, 2011 | 09:54 PM
JJ 86's Avatar
JJ 86
That's what I was thinking. However, problem solved. Bought a new alt. and everything is good to go. Thanks for everyone's help.
Old Aug 5, 2011 | 10:24 PM
BigGun's Avatar
BigGun
Are you going to take it apart and have it powder coated.
Old Aug 6, 2011 | 01:24 AM
cdkcorvette7
I was wondering the same thing...
Old Aug 6, 2011 | 06:45 AM
JJ 86's Avatar
JJ 86
Nope...
To Where is the ground for the alt.
