Security light
Old Jul 13, 2011 | 03:18 PM
don8585's Avatar
don8585
Default Security light
I have a security light on steady while driving but only occasionally about every other start cycle. I get a 2721 code only when the light comes on, the strangest thing that goes along with this is the car forgets the FOB about once a week and I have to reproram it. I used to have a start problem wth the pass code key but that has subsided when I found a connector bad on key harness? I have done everything on Bill's thread and more but still have electrical gremlin running around in car.
Old Jul 13, 2011 | 03:49 PM
DeeGee's Avatar
DeeGee
You posted afew things there that could be unrelated problems
Focussing on the security light, you probably have a worn ignition barrel. Do you carry a lot of weight on your key ring? It may be causing the key to drop in the ignition and the VATS pellet may not be making a good contact. try your back up key and leave everything off the keyring to see if it improves.
Old Jul 13, 2011 | 04:29 PM
ZeeOSix's Avatar
ZeeOSix
To add, clean the metal strip on the key pellet with a soft pencil eraser. When my Security light would come on and I had no start conditions, even my spare key (which had NEVER even been used) caused the issue.
Seems that metal strip on the pellet on the spare key I never used even got some kind of coating on it from just sitting. I cleaned both key pellets with the pencil eraser and it cured the Security light from coming back on.
Old Jul 13, 2011 | 07:06 PM
don8585's Avatar
don8585
thanks I will try that dirty key and barrel worn. car does have 128,000 miles so ignition barrel could be wearing out. Thanks
Old Jul 13, 2011 | 09:02 PM
FFIN90's Avatar
FFIN90
From: = From Toronto = 9/11/01 FDNY 343 Never Forget
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
I recently had no start issues with the security light coming on and codes for the security system and "pull key wait 10 sec" messages .
I ended up replacing the ignition switch, after opening up the old one I now know why the car was giving all kinds of codes.
No issues since the swap.
Just a few burnt contacts on the old switch:
Old Jul 14, 2011 | 02:25 AM
DeeGee's Avatar
DeeGee
Useful pic thanks
Old Jul 14, 2011 | 02:28 PM
FFIN90's Avatar
FFIN90
Useful pic thanks
Your welcome
Old Jul 18, 2011 | 11:34 AM
don8585's Avatar
don8585
Great Pics, Thanks. I actually ordered a new switch since the car has 128,000 mi. Start problems have risen again so maybe new tumbler and switch will cure the problems.
Old Jul 18, 2011 | 02:00 PM
lucky131969's Avatar
lucky131969
A bad ignition switch will not precipitate a B2721......a bad(or flaky) lock cylinder will. Not saying you do not have two problems.......just being specific....
Old Jul 18, 2011 | 02:22 PM
don8585's Avatar
don8585
Lucky, actually ordered new switch with tumbler and new key. Thanks
Old Jul 19, 2011 | 12:35 PM
don8585's Avatar
don8585
All,
I installed a different switch and barrel complete. Did have a few problems getting everything working again but so far so good. No codes or security light, also starts everytime. I will give it a week and reply again if fixed or not. I changed the Battery, starter, theft deterrent relay, cleaned all grounds, VOM'd all wires and it looks like it might have been the key cylinder the whole time. Car has 128,000 miles so beware the lock cylinders do wear out. I will let everyone know soon if this actually fixed the problem permanently. Thank you BC, Lucky and everyone else that helped with this.
Old Jul 19, 2011 | 01:46 PM
DeeGee's Avatar
DeeGee
Glad we got to the bottom of the problem
Old Sep 19, 2011 | 02:10 PM
don8585's Avatar
don8585
Lucky, Curlee and others. I wanterd to update all of you that helped with the starting problems and secutity light after changing all the items which included;
Battery
Theft deterrant relay
starter
and repair of numerous connectors and wringing out all the wiring it eneded up being the tumbler and aftertI changed it I have not had a code or a start problem for 2 months. Thank you everyone for your input and help.
Don
Old Sep 19, 2011 | 02:13 PM
lucky131969
Battery
starter
Don
Glad to hear. Thanks for the follow up
To Security light
