From: Wylie TX --> Less is More, except under the hood !
Originally Posted by $$$frumnuttin'
Are there any noises, or other symptoms? It's an A4 and I am at 58k summer miles over a 15 year run...
I changed mine 6 months ago. I have 20K miles on the car, and its 7 yrs old. I just figured it was time to change this stuff. I wanted to learn how to do it myself too. I feel better knowing that all my fluids are new (Coolant,Diff, Tranny,Brake fluid, Clutch fluid etc..)
I changed mine at 78,000 miles, ten years. The old oil was dirty.
Easy to do.
I use Redline in the engine, trans (auto) and differential.
For more on Redline, there is a comprehensive article regarding oils and flat tappet cam failures at corvetteactioncenter.com under the Featured Article heading you will find More Articles and "Engine Oil Deep Dive".
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
thanks guys...I will change it now even without symptoms...I have the GM fluid with the additive already mixed in...should be equivalent to the other brands, right?
