Finally had enough
Old Jul 15, 2011 | 02:30 PM
BryanB83's Avatar
BryanB83
Default Finally had enough
I need some help guys......
1. Driver side door lock has stopped working (unlock works)
2. Auto door locks not working (when driving)
3. Trunk release having issues (having to pry open)
4. lights are dim on options cluster (and on radio *****)
1999 FRC
any hlep would be greatly appreciated.
thanks,
BryanB
Old Jul 15, 2011 | 07:46 PM
SUPERCRUZ's Avatar
SUPERCRUZ
Pull codes from the DIC and report.
Old Jul 16, 2011 | 07:02 AM
Joevette99's Avatar
Joevette99
Default Item # 3
I had same problem. Next time you open it, lubricate the latch. Did wonders for my '99. I hope it is that simple.
Old Jul 17, 2011 | 09:14 AM
Joe_Planet's Avatar
Joe_Planet
1. Door control module. The locking relay is toast, so either replace the relay or module.
3. Sometimes I use a trick. Hit the trunk button on the inside and close the door. The air pressure will help pop it open.
To Finally had enough
