C5 suspension lubrication
Old Jul 15, 2011 | 04:42 PM
vettedude521's Avatar
vettedude521
Default C5 suspension lubrication
Short of using a needle to inject lube into each rubber boot, is there any way to lube the chassis joints? I had a terrible squeek on the drivers side rear suspension. I raised the car, loosened the bolt for the lower a arm? and sprayed silicone lubricant , then re tightened the bolt. Squeek is gone but I would like to lubricate all other fittings. Thanks
Old Jul 26, 2011 | 01:36 AM
klwhitacre's Avatar
klwhitacre
Sorry I can help with the chassis joint lube issue, but I have a suggestion for you to try to get rid of some squeaks. On my C5Z, I had a creaky-squeaky noise when the suspension traveled. It was coming from both the front and the rear, so it ruled out a U-joint issue (I don't have an AWD Z06!). It was worse when it was hot, and it was driving me insane! I hit the forum and scoured through a bunch of really great ideas. The one I settled on was that my anti roll bar bushings were to blame. I used spray silicone and hit the bushings really well - squeak was gone! If you haven't tried this yet, they're really easy to reach. Good luck.
Kevin
Old Jul 26, 2011 | 10:29 PM
mcgilles's Avatar
mcgilles
I'm curious to know what exactly you meant. Which bolt did you remove? how did you get lube into an area that helped?
I had a nasty squeak for a long time. I think I fixed it with a new tie rod end and new swabyars complete with new end links and bushings. it was a nice upgrade at the same time. I haven't heard a sound in a few weeks, but prior to that I did still hear it a couple of times. just in case this comes back and I need some new way to try to fight it...
Old Jul 26, 2011 | 11:36 PM
vettedude521
I'll have to look up a diagram, but the bolt I loosened is at the upper A arm suspension, it has a rubber bushing and when I sprayed the silicone lube in it, it seemed to quiet the squeek. I sprayed every piece of rubber I saw at the time. The poster prior to yours also added some good info that I will look at next time I put the car up. Thanks for the reply
Old Aug 1, 2011 | 05:26 PM
yyzmsp's Avatar
yyzmsp
From: maple grove and North Port fl mn and now florida
I've had several C5 s and I have found that most times the creaking/squeaking comes from the swaybar bushings. Just loosen the swaybar bolts and lube the rubber grommets... hope this helps
Old Aug 1, 2011 | 06:27 PM
vettenuts's Avatar
vettenuts
Sway bars are the typical culprit. I used Teflon tape on my last installation, no noise since. Won't use "lube" again. Plus the Teflon tape is not messy.
Old Aug 4, 2011 | 09:32 PM
vetterss's Avatar
vetterss
Default suspension noise
I had a post earlier about creaking noise on my '00 hardtop. It was the sway bar bushings and I used wheel bearing grease and the sound is gone.
Old Aug 24, 2011 | 01:23 AM
flynhi's Avatar
flynhi
I was skeptical about Teflon but it cured my front suspension popping sound. Recommended!
Old Aug 24, 2011 | 02:23 AM
vettedude521
I'll look into this on the weekend Thanks all
To C5 suspension lubrication
