Headlight Problem
Old Jul 16, 2011 | 10:20 AM
davehirst's Avatar
davehirst
Default Headlight Problem
The other day, I pulled out of my garage, and of course my headlights popped up. As I sat in the sun waiting for my wife, the lights closed, and I heard this awful noise, like a griding chatter. Opening the hood I turned the lights on and no noise, but when turning them off, the same noise. The motor on the drivers headlight keeps turning for about 5 seconds after the light is down, and makes the awful noise. Do you think it might be the headlight control unit? Any suggestions? By the way its a 2000 C5.
Old Aug 18, 2011 | 06:46 PM
sojo's Avatar
sojo
Default Same Problem
I'm having the same problem.....have you found your problem?? thx Sojo
Old Aug 18, 2011 | 06:53 PM
GoBallsDeep!'s Avatar
GoBallsDeep!
Your gears for your headlight is stripped. Upgrade to brass
http://forums.corvetteforum.com/c5-g...placement.html
Old Aug 18, 2011 | 08:47 PM
guido7834's Avatar
guido7834
Gear is shot. Just did mine this week. Not a bad job at all.
Old Aug 18, 2011 | 08:49 PM
guido7834's Avatar
guido7834
http://forums.corvetteforum.com/c5-g...orialized.html
Old Aug 19, 2011 | 10:55 AM
Ultimate ride's Avatar
Ultimate ride
I just finished replacing both of mine. The driver's side gear was bad and the one on the passenger side was on the way out. Easy job unless you drop a bolt down there like I did on the second one.
Old Aug 19, 2011 | 03:28 PM
guido7834's Avatar
guido7834
Yea, I dropped a wrench down below the battery as I was removing the negative side! Fished it out with a retractable magnet. It's always the simple stuff that causes the most headaches!
To Headlight Problem
