Tire pressue zero
Old Jul 16, 2011 | 01:36 PM
Tom Hudson's Avatar
Tom Hudson
Default Tire pressue zero
I had new tires installed yesterday - Now the gauge says Left front - 0 Pressure - do no drive over 55 MPH or whatever - I can remove the message but it comes back - even on the HUD it says check gauges - hit reset & it goes away for a few miles - but come back - Rest of the tires read without issue.
So how do I fix this - I let all the air out of the tire & refilled it a couple of times, thinking it might jar something - but still have the problem -
Thanks - tom
Old Jul 16, 2011 | 01:37 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
you need to do a relearn of the TPMS...
Old Jul 16, 2011 | 01:39 PM
Tom Hudson's Avatar
Tom Hudson
Old Jul 16, 2011 | 01:44 PM
Paul Huizenga's Avatar
Paul Huizenga
FNG to the rescue!
http://www.corvetteonline.com/tech-s...nitor-sensors/
Article and video on resetting the Tire Pressure Monitoring System sensors on a C5
Old Jul 16, 2011 | 02:22 PM
Tom Hudson's Avatar
Tom Hudson
Originally Posted by Paul Huizenga
FNG to the rescue!
Thanks Paul -
It says to press reset to clear any warnings? - Mine won't clear the warning -
I can go to options & get a blank screen & do the rest of the steps but but this doesn't help my problem -
I guess if I can't clear the warnings - I might be screwed?????
I'll go out and mess with it some more - tom
Old Jul 16, 2011 | 02:40 PM
Paul Huizenga
Originally Posted by Tom Hudson
Thanks Paul -
In the context of doing the TPMS reset, you're just clearing the "door ajar" and getting to the blank screen. If going through and resetting all the sensors with a magnet doesn't cause the sensor that's reading 0 PSI to clear and give a good pressure reading, you're going to have to replace the sensor in that wheel, I'm afraid...
Old Jul 16, 2011 | 02:45 PM
Tom Hudson's Avatar
Tom Hudson
door jar goes away when i hit reset but it then goes to the 0 pressure message again? once it's on o pressure the reset does nothing? press it 10 times & it still says the same zero message - won't go to a blank message board?
Old Jul 16, 2011 | 03:04 PM
Paul Huizenga
Hmm... In that case, I think you need to let the TPMS go to "sleep", and I can't remember how long you have to let the car sit before that happens. Perhaps somebody with an owners manual handy can answer that question.
Old Jul 16, 2011 | 03:24 PM
Tom Hudson's Avatar
Tom Hudson
I just looked in the owners manual Paul - didn't see anything about that - maybe in a shop manual?
Old Jul 16, 2011 | 03:59 PM
jrose7004's Avatar
jrose7004
There you are!
Old Jul 16, 2011 | 04:24 PM
Tom Hudson's Avatar
Tom Hudson
Originally Posted by jrose7004
There you are!
Just show me the way old master - I will follow
Old Jul 16, 2011 | 04:47 PM
65GGvert's Avatar
65GGvert
Are you holding the reset to clear the error,or just pressing quickly?
Old Jul 16, 2011 | 04:55 PM
Tom Hudson's Avatar
Tom Hudson
All of the above!!!!!! and every where inbetween
tom
Old Jul 16, 2011 | 05:33 PM
Tom Hudson's Avatar
Tom Hudson
Hey Paul - what if I disconnected the battey - would that help the TPMS get the rest it needs or would that just open up other issues?
tom
Old Jul 16, 2011 | 05:44 PM
65GGvert's Avatar
65GGvert
Here's another thought. What if they programmed the sensors (or put them in a different position if they didn't program) and one of your tires really has no pressure? Did you check with a gauge to see if your other three tires had pressure? This is assuming runflats.
Old Jul 16, 2011 | 06:22 PM
Tom Hudson's Avatar
Tom Hudson
I went with Stones - non-runflats this time - nope - all the tires have 30 lbs in them - tom
Old Jul 16, 2011 | 06:31 PM
Tom Hudson's Avatar
Tom Hudson
I can get a blank screen & I can get the "Learn Left Front Tire" message to come up - But I can't get there the way Paul did in his video -
Since I "can" get the "Learn Left Front Display" message to come up - should I still be able to re-program regardless of how I got there?
I tried 3 different magnets - they are strong but I don't have a round one like Paul used in his video -
I'll go & try to find one if someone thinks it's worth a shot?
To Tire pressue zero
Old Jul 16, 2011 | 09:56 PM
BigGun's Avatar
BigGun
I would take it back to whoever installed your tires. They may have damaged it when they did the tires, not uncommon if they were careless or in a hurry. Most tire shops should also be able to program your sensors for you.
Old Jul 16, 2011 | 11:34 PM
dmarkshark's Avatar
dmarkshark
I would think if it beeps, recognizing the magnet/sensor, you would be fine and to continue on around the other tires.You don't need a round magnet, just one that is strong enough, I used a speaker magnet to do mine.
Old Jul 16, 2011 | 11:38 PM
Tom Hudson's Avatar
Tom Hudson
I don't get a beep!
