No display in comfort control panel
I'm getting nothing of display in my comfort control panel
no temp, no mode, no outside temp, nothing. All the other lighting dash and radio work.
Is there a fuse for that or is this a bigger problem?
Thanks,
Ron (aka Guppie)
How good is your soldering? Heres a DIY fix if you're feeling brave
http://forums.corvetteforum.com/c5-t...splay-fix.html
It didn't take no more than a half and hour to pull it out and solder those connections, reinstall it and it works PERFECTLY!!!!
I only touched the connections at each end of the little do-dads "241" and didn't even add additonal solder, the tiny tip of the solder iron was all it needed. I used magnifying eyeglasses and a bright light which made it SO easy!
Best $26 I ever spent on the soldering iron and solder!
